Varbration when brakeing
imye30
Thu Dec 29, 2011 5:47 pm
I have a e46 4 door on a y plate when driving on the motorway an braking getting a varbration from the front brakes will this be the pads or disks need changing
Rtaylor2208
Thu Dec 29, 2011 6:37 pm
Possibly both, no way of knowing till you take the pads out first.
Sanchez
Thu Dec 29, 2011 6:39 pm
Could be warped discs.
Thu Dec 29, 2011 7:16 pm
Does the vibration only happen when braking?
imye30
Thu Dec 29, 2011 7:20 pm
Yes wen braking some times wen not braking a humming noise from the front passenger side
Thu Dec 29, 2011 7:57 pm
Sometimes when not braking?
When it starts happening again, pull over a feel how hot the front wheels are. You say the noise is coming from the front passenger side then its likely that that side will be hotter.
If this is the case then the bake caliper could be sticking, quite common on E46's.
imye30
Thu Dec 29, 2011 8:08 pm
Cheers guys could it be the wheel Bearing that could be making the humming noise
zaust
Zone day release
Fri Dec 30, 2011 9:49 am
Vibration when braking is a warped disc. The humming is either a pad that is stuck to the disc slightly as the caliper is no fully sliding back. Or a wheel bearing.
M30 Tech 1 Touring on gas.
kingludba
Fri Dec 30, 2011 10:08 am
just fork out and change them all , will cost but at least its done and you have peace of mind......until the vibration starts at the rear....... :mad:
AndyG
Fri Dec 30, 2011 10:51 am
when did the car have its lower wishbones and bushes changed last? On mine this was the main culprit, but as my discs and pads were worn as well I replaced them all, and that cured the vibration and wobbles felt
