E46 heater blower stop working
imye30
Post Fri Oct 07, 2011 8:11 am
Got in my car this morning turn on the fan to de mist the front an nothing every thing lights up but no air even the fan speed setting shows speed what can this be
Ajsingh
Post Fri Oct 07, 2011 9:22 am
Possibly a heater blower resistor. Common failure on e46's.. Its a metal spiked object that is located drivers footwell on the upper left part. Can be a right arse to take out
E30 Crazy!
blingsta
Boost Junkie
Post Fri Oct 07, 2011 9:34 am
yep.. as above, the classis hedgehog problem.. do the lights also work when keys out of ignition? could drain the battery
imye30
Post Fri Oct 07, 2011 9:49 am
blingsta wrote:yep.. as above, the classis hedgehog problem.. do the lights also work when keys out of ignition? could drain the battery
U mean the control lights for the blower
pony
Post Mon Oct 10, 2011 9:48 pm
on mine the fan stays on (sometimes) even once you have switched ignitionoff - is that the hedgehog thing and what causes it precisely?
the lights are off by the way.
Post Mon Oct 10, 2011 9:58 pm
pony wrote:on mine the fan stays on (sometimes) even once you have switched ignitionoff - is that the hedgehog thing and what causes it precisely?
100% it will be the final stage or "hedge hog". Its the heater blower motor resistor and they short out internally causing the fan to stay on intermittently which can cause a battery drain.
VERY common on E46/E39/E53, usually a stock item at BMW dealers.
pony
Post Mon Oct 10, 2011 10:02 pm
what is the final stage? Hedgehog you mean the heater blower motor i presume. Is it expensive/time consuming to get rectified?
Currently, the particular fuse for this circuit is taken out so it does not happen.
Post Mon Oct 10, 2011 10:07 pm
Its what i said it is!
BMW call it the "Final stage"
Its common nick name is "hedgehog"
What it is, is the blower motors resistor, separate from the motor.
They are fiddly to change on E46's but not time consuming.
Post Mon Oct 10, 2011 11:04 pm
One of these. Hence the name "hedgehog" :D
http://www.ebay.co.uk/itm/BMW-E46-E39-X ... 5ad55d7112
zaust
Zone day release
Post Thu Oct 13, 2011 7:15 pm
Had to do the hedgehog and the top stepper motor for the screen vents a month or so ago. Was my first time on e46. Not to bad for the hedgehog but the stepper was a bitch x2.
M30 Tech 1 Touring on gas.
