Plus, is it normal that when you plant your foot, it smokes like crazy? i thought you should get a puff of black smoke then it clears up? but mine seems to chuck smoke out constantly on full throttle ?
Any advice will be greatly appreciated
Check your turbo hoses - even a small split in one of the pipes will be amplified massively when it comes on boost causing it to overfuel and chuck out the black smoke when under load.blingsta wrote:Plus, is it normal that when you plant your foot, it smokes like crazy? i thought you should get a puff of black smoke then it clears up? but mine seems to chuck smoke out constantly on full throttle ?
im gonna give it a full service very soon, should hopefully do the trickirish320i wrote:Its very unlikely your particule filter is causing this problem has the oil system breather filter been changed recently I have seen these block and cause massive amounts of smoke on the e46s.
Indeed, I heard about this in the dealers a few weeks ago. I had to sit down and I wasn't buying onedave525 wrote:price up a new particle filter. best be sitting down.
