Hi all,
I have a m3 evo 3.2 manual, it has 128,000 on the clock with fully stamped BMW history at correct intervals all the way through and the car has only 2 previous owners, with this in mind i am having some work done on the 24th of Aug by Mr Vanos,....
1) The valve timing is being carried out changing shims etc
2) reconditioned Vanos units and gears
3) All oils and filters including final drive
Totalling £1000
The car does run really really well and pulls like a steam train but the vanos unit is really noisy so I want to do it anyway, but my dilema is that the car has 130k on the clock and ive recently read some nightmare stories of spun shells and allsorts and im worried if im going to do all of this work and then BANG something else happens?
It has been recommended to me to change the oil pump and end bearing shells and uprate ARP bolts but that would be another £800 and im happy to lay out a bag of sand but not 2!
What do you guys think??
And thanks for your advice in advance
advice on e36 m3 please?
xavi1980
NUMBER PLATE FOR SALE
(S23 EVO) PM ME OFFERS
SteMarsden
I think that the vanos is a personal thing, loads of people just let them rattle their t1ts off but Id probably have it done too if the car was a keeper.
Put a set of ARP rod bolts in it for £80 plus £12 for the sump gasket which should protect the bottom end from spinning shells and enjoy your car!
BMW E30 318i ex PBMWC track car
2011 VW Passat Est
2011 VW Passat Est
Falkster
To be honest it's only gonna happen if you ring it's neck everytime you drive, personally I wouldn't even do the vanos - most have a rumble. Just enjoy the car, remember you bought it to break it so even if you broke it you've enjoyed it for so long.
xavi1980
that's a good idea, I will do the bolts and just service the oil pump, do you know where I can get ARP bolts from? And what would you expect to pay for a oil pump?SteMarsden wrote:I think that the vanos is a personal thing, loads of people just let them rattle their t1ts off but Id probably have it done too if the car was a keeper.
Thanks again
SteMarsden
http://www.arrowprecision.co.uk/details.php?id=69276
Try CotswoldBMW on here for your OE BMW bits.
HTH.
Ste.
HTH.
Ste.
2011 VW Passat Est
2011 VW Passat Est
