must look pretty much oem, i just want something to bring the bumper down to the same level as the front edge of the sills. something like the standard e30 lip but with a bit of a curve might work.
seen replica alpina lips which give the depth and are pretty subtle, but i wonder about them lasting when theyll be running pretty close to the ground, plus they have the alpina lettering moulding in which i would be wanting to remove.
seen another lip, similar to the e30 is lip in style, but way too deep for my car. laguna lip is a bit too oldschool and i prefer smooth and unvented. doesnt need to be deep, 50mm would probably be enough just to finish off the front end.
has to work with a standard basemodel front bumper too as i like the clean simple lines and don't want to go for an m3 style bumper.
this is the only pic that shows the height difference clearly,
ideas, suggestions opinions welcomed
