cossie
e30den
Post Thu Mar 19, 2009 8:52 pm
2.9 cossie in an e30. will it fit :mad:
blingsta
Boost Junkie
Post Thu Mar 19, 2009 9:55 pm
everything is possible mate..
Post Thu Mar 19, 2009 10:04 pm
Fuzzy has a cossie engine in his, don't think it's a 2.9 though.
As Blingsta said, anything is possible, you can get a V12 in a E30 :cool: :cool:
Depends on how much cash you want to throw at it
Eddie25
Post Thu Mar 19, 2009 10:07 pm
V6 out the Granada Cosworth i'm guessing. My mate had a Sierra XR4 in 12v form. Still a lovely engine.
Don't see any reason why it shouldnt fit, case of getting the tape measure out i would think.
bodger
Post Thu Mar 19, 2009 10:09 pm
what box would you use?
Post Thu Mar 19, 2009 10:20 pm
bodger wrote:what box would you use?
Ford type 9 or ford sierra cosworth 2wd borg warner T5 box.
Post Thu Mar 19, 2009 10:24 pm
The 2.9 24v cosworth engine based on fords cologne v6 is a good engine. I have rebuilt one after the timing chain tension went slack and bent some valves, this was due to lack of oil changes!
I wouldn't put one in an E30 though! An M52B28 has near on the same power and fits a whole load easier.
If you have the 24v engine, put it in a Sierra or capri.
Post Thu Mar 19, 2009 10:35 pm
Best place for a nasty ford V6 is a skip ! :)
78dude
Post Fri Mar 20, 2009 2:53 pm
It is odd that some one havent used an Audi 2.2 or 2.3 5 cylinder engine in a E30...
It maybe the best engine for tuning and what a sound it makes! winkeye
d6dph
Post Fri Mar 20, 2009 2:56 pm
pacerpete wrote:Best place for a nasty ford V6 is a skip ! :)
Some would say an E30 is a perfect home then Pete :D
e30den
Post Fri Mar 20, 2009 6:06 pm
just bouncing a few idea,s around, my 2.5 is showing signs of head trouble, it does,nt over heat
but there is oil and water mixing, a good time to put something else in i reckon.
Post Fri Mar 20, 2009 6:18 pm
bss325i wrote:The 2.9 24v cosworth engine based on fords cologne v6 is a good engine. I have rebuilt one after the timing chain tension went slack and bent some valves, this was due to lack of oil changes!
+1 Cracking engine - the old shape ( pre-frog look ) Scorpio 24v would do 140 easy winkeye ...... on a "private" road of course..........
Morat
Post Fri Mar 20, 2009 7:17 pm
OMG, you just reminded me of the froggy look scorpios. hahahhahahaha.
BMW/Merc/Audi must have had a few beers the first time they saw those :)
Post Fri Mar 20, 2009 7:41 pm
Morat wrote:OMG, you just reminded me of the froggy look scorpios. hahahhahahaha.
Despite the "aquired taste" looks, the frog eye 24V was a very good peice of kit and in terms of engineering, was a step up from the mk3 granada/scorpio shape.
A very late frog eye scorp' with the smoked headlamps and colour coded front grill with a set of 17" softline RS seven spokes looked ok.
Post Fri Mar 20, 2009 9:37 pm
Must be a very acquired taste - I'm a fan of plenty of blue-oval stuff but when they brought out the frog-scorpio that pretty much killed my interest in new Fords.
The last of the pre-frog 24v Scorpio is still one of my favourites though - still the quickest I have ever driven a car - if I had the space I would love a Dark metallic blue one with the black leather trim - proper car ! :cool:
Post Fri Mar 20, 2009 10:53 pm
A friend of mine had a dark met blue one with black leather, a hatch that i used to look after.
I always prefered the saloon.
If only they made a manual 24V or even a 4x4 24V!
Zizzle
Post Sat Mar 21, 2009 5:22 pm
I had one... If only i new you earlier.. winkeye
its was beautiful and alot of fun!!!
e30den
Post Sat Mar 21, 2009 8:08 pm
had a capri years ago, wish i still had it oh well, sh#t happens
fuzzy
He who sleeps with "Gingers"
Post Sat Mar 21, 2009 8:10 pm
ImysE30 wrote:Fuzzy has a cossie engine in his, don't think it's a 2.9 though.
different cosworth engine. i used the proper one :D
jbh
Hartge Crew
Post Sun Mar 22, 2009 3:29 am
78dude wrote:It is odd that some one havent used an Audi 2.2 or 2.3 5 cylinder engine in a E30...
i did think about using my old 2.3 engine from my old Audi a few years back to put into a 318i but some bloke chapped my door and made me a silly offer on the engine that i couldn't refuse :mad:
me and my brother was talking about this a few days ago... im thinking on getting another E30 now to abuse with an Audi engine winkeye
need to get my sport finished first
jonb
Post Sun Mar 22, 2009 7:37 pm
Waste of time.
What are you going to gain by spending all those hours labour putting it in. It would be massive work to retrofit, and you will end up with a car no better dynamically then the car it came out of.
