e36 m44 lumpy idle
town325i
this problem has just started and it happens when the car is cold and at running temp ive ordered new inlet gaskets as they are only pence so im going to change them first
Jeepster
Common for the boot between the maf and the inlet to crack, worth a check.
town325i
ive replaced this as matter of cause allready when i changed the crank sensor
Jeepster
You haven't just changed the plugs or anything have you? ICV is always worth a check too.
town325i
i serviced it in january with genuine parts because they were cheaper than pattern parts. where is the icv hidden on these and can you take them apart to clean them out?
town325i
found the problem broken oil breather pipe by the bulkhead
town325i
now all ive got to do is get a water pump pully and fit that after i broke it trying to get the viscus fan off that some coont had lock tighted on
