E36 Sport shopping...
Post Wed Feb 02, 2011 2:10 pm
Royalratch wrote:
pacerpete wrote:
Royalratch wrote:Exactly.
My brother had a lovely one for ages which I quite liked. Until he drove it too long and let it overheat and cooked the head.
Twins ? :eek:
I'm still holding out for it to not be terminally cooked properly yet. winkeye
Paris with that diff/ commotion was brave, with that leak :o
Royalratch
Post Wed Feb 02, 2011 2:14 pm
It added a little drama to an otherwise dull adventure.
You wouldn't know the engine is on fire under there...
Andyboy
Alpina Colada
Post Wed Feb 02, 2011 2:31 pm
pacerpete wrote:
Andyboy wrote:
pacerpete wrote: Twins ? :eek:
Pete, you crack me up......... winkeye
Just seen your PROFILE on ratemypoo.com ! :eek:
Okay Pete, your starter for 3...........who co-sang 'under pressure' with Queen?
Post Wed Feb 02, 2011 3:20 pm
Royalratch wrote:It added a little drama to an otherwise dull adventure.
No puddle means its empty ! how did you get back ? :(
Royalratch
Post Wed Feb 02, 2011 3:29 pm
For those in the dark, my mighty M42 has finally given up the ghost and decided to overheat on a semi-permanent basis. At best a head/profile gasket at worst a cracked head. I had a good run at 130K trouble free miles.
Pete - it was totally fine until the return leg - I just stopped every hour and refilled to get home.
The question now is, new head, new M42 or add 2 Cylinders.
Andyboy
Alpina Colada
Post Wed Feb 02, 2011 5:14 pm
I picked up a very cheap 318iS E36 last year with this issue. You'd fill the cooling system (I removed the stat) and it would start of 3 pots with a good puff of steam from the Zorst. It would go for about 10 miles quite okay, heater on hot - and when it went cold, you knew it needed water. Pull over, add coolant and it would fire up again on 3 with a superb steam display before latching onto 4 again - and no more steam. I did a 6 mile stretch down the A1 at 70 and it was okay but just off it, it needed more.
Four cracks in the head on cyls 2 and 3, exhaust valve seat to the waterway. I still have it as a trophy.
Post Wed Feb 02, 2011 5:18 pm
K-Seal FTW :)
Post Wed Feb 02, 2011 5:22 pm
As I keep telling you, it's M52 time!
Andyboy
Alpina Colada
Post Wed Feb 02, 2011 5:54 pm
But the M52 is such a heavy engine - think of the legendary handling balance..... :D
tim_s
Post Wed Feb 02, 2011 6:01 pm
Andyboy wrote:I picked up a very cheap 318iS E36 last year with this issue. You'd fill the cooling system (I removed the stat) and it would start of 3 pots with a good puff of steam from the Zorst. It would go for about 10 miles quite okay, heater on hot - and when it went cold, you knew it needed water. Pull over, add coolant and it would fire up again on 3 with a superb steam display before latching onto 4 again - and no more steam. I did a 6 mile stretch down the A1 at 70 and it was okay but just off it, it needed more.
Nice! I think the head goes due to gasket failure on these, but that's def where to check, where it's got the big slotted hole in the head but only little ones in the gasket on cyl 2 . In the ones I've seen (mainly on t'internet) you can see where the gasket has failed, the subsequent nastiness the engine's been put through then seems to kill the head.
2.1 318is, MS, LPG. 200bhp, 175ft/lbs GONE!
Boxster, e46 m3, e36 sport touring and alpina B3 3.0
tim_s
Post Wed Feb 02, 2011 6:03 pm
Andyboy wrote:But the M52 is such a heavy engine - think of the legendary handling balance..... :D
Sweepstakes on whether Ratch folds on the m42!?
Royalratch
Post Wed Feb 02, 2011 6:24 pm
That's exactly what happened on mine except I could do a hundred miles until refill time.
I removed the throttle heater plate some time ago and plugged the coolant port that feeds it - do you think this was a cause? Was done a while ago tho...
Post Wed Feb 02, 2011 6:27 pm
cooks ferry is the bloody cause by the sounds of it.
Post Wed Feb 02, 2011 6:33 pm
Great picture. Your IS looks very nice.
Andyboy
Alpina Colada
Post Wed Feb 02, 2011 6:46 pm
No, that wouldn't cause it. M42 heads cracking are mostly caused by overheating and insufficient coolant as opposed to a design fault. My Compact for example came to me with a cracked head (Cyls 2 and 3, four cracks - identical failure to the iS Coupe head) and it had been bodged up with K Seal or some other evil muck. The reason it was overheating was a missing fan shroud - when driving, there's air going through the rad but in traffic there isn't. The shroud is there because the fan is too far away from the rad and without it, the fan cannot get any heat from the rad to engage the clutch.............so it just overheats. E36 gauges are also 'buffered' meaning that even though the needle is in the centre, it can still be very close to boiling. By the time the needle starts to move up to 3/4 and the red, it's already boiling its tits off.
When you get two cracks on one cylinder, the area of cylinder head between the cracks relaxes its nip on the head gasket - the two I've done showed distinct blow by on the gasket in this area.
The company mentioned ^^^^^ sound like a right shower. :roll:
Royalratch
Post Wed Feb 02, 2011 6:56 pm
Sounds like the temp gauges are buffered the wrong way.
I guess Cooks Ferry are a bit slapdash these days - they didn't use to be but the guy there who knows his stuff is quite hands off now. They had the head off an E46 M3 the other day so they know what they're doing but it's all in the details I with these older cars now.
Like I said, 130K isn;t bad - I don;t even know if it had the Profile Gasket recall...
Anyway - E36 Sport Tourings - where are they all!
Post Wed Feb 02, 2011 7:25 pm
Sorry but just because the head is off of something, does not mean they are competant!
The more knowledgeable guy may know his stuff but if he employs incompetent staff then he is just as bad as they are.
Royalratch
Post Wed Feb 02, 2011 7:38 pm
Lol the HATE. :twisted:
Post Wed Feb 02, 2011 7:47 pm
No hate, just ROFL at there workmanship.
Post Wed Feb 02, 2011 8:05 pm
I've got pictures ! :eek: On a positive note, if anybody has a rusty hanging turd (as if!)and needs an MOT , I have a new number ! 8O
Royalratch
Post Wed Feb 02, 2011 8:11 pm
Pete - you can MOT out of your joint? :eek:
Post Wed Feb 02, 2011 8:14 pm
Royalratch wrote:Pete - you can MOT out of your joint? :eek:
Not quite but your (ex) mate Pat ,can and does ! :eek:
Andyboy
Alpina Colada
Post Wed Feb 02, 2011 10:15 pm
I understand a VOSA teleportal is used whereby the vehicle being tested is examined via satellite and the certificate arrives via Royal Mail.
Post Wed Feb 02, 2011 10:42 pm
pacerpete wrote:I've got pictures ! :eek: On a positive note, if anybody has a rusty hanging turd (as if!)and needs an MOT , I have a new number ! 8O
no biscuits required?
tim_s
Post Thu Feb 03, 2011 9:45 am
On coolant plate, ideally you shouldn't blank it off but bypass it imo dude, run a hose direct from the plastic port in the block up to the one in the cyl head just bypassing running around the heater plates. It prob shouldn't make much odds as it's the one at the back of the head that does the work, but still I wouldn't want to mess with how the thing was designed and so would keep that passage of flow open.
what's with cook's ferry? you got the head off yet? Jog on, let's see how badly you've toasted it!
Royalratch
Post Thu Feb 03, 2011 11:05 am
Cooks Ferry did a complete timing case /gear renewal for me and returned the car minus ANY coolant and also didn't remove the old Tstat gasket when fitting the new one - so it was seated with 2 gaskets and not sealing properly.
I didn't use the car for months but when I did all these issues came about - so yes it could be their fault but how do you go back to them now. I guess I was due a headache after 13 years and 130K.
I'm parking it up till it's sunny then either Pacer will have a look if he can or I will boogie on it - can't do any worse lol.
tim_s
Post Thu Feb 03, 2011 12:04 pm
ah def sounds like they f**ked it, not cool. Though could mean head's ok if you haven't overheated it too much.
Head off is only an hr or two's work on these:
1) Remove the two inlet pieces and water hose (just unbolt stuff and leave it cast aside, no need to completely remove or disconnect fuel lines etc)
2) Remove valve cover
3) Remove exhaust (just unbolt and leave it cast aside, no need to completely remove)
4) remove top timing case and t stat housing
5) Put engine in TDC, remove cam pulleys
6) Unbolt head
If you want to unbolt everything I'll gladly swing by and remove/inspect/refit the head.
*If* the head's good, for a couple of hours work could have her back on the road with shiny new HG/profile gasket in there. If you're leaving her parked up, take the plugs out, turn the engine a bit and oil the bores to stop the coolant in there destroying them.
Post Thu Feb 03, 2011 2:46 pm
Definately not profile gasket , there is coolant getting into the cylinders. It's missing when started after being left for a while. I will pull the plugs later if I get a chance and crank it . To be honest, I am expecting the head to be cracked :(
mabz
Post Thu Feb 03, 2011 7:59 pm
found this one ratch not everyones cup of tea but i love it.just needs the wheels sending back to china/dairylee factory stick some originals on and jobs a goodun.
http://www.pistonheads.co.uk/sales/2465730.htm
Post Thu Feb 03, 2011 8:38 pm
mabz wrote:found this one ratch not everyones cup of tea but i love it.just needs the wheels sending back to china/dairylee factory stick some originals on and jobs a goodun.
This will be rubbish, I'll put money on it .
Royalratch
Post Thu Feb 03, 2011 8:57 pm
Dude it's YELLOW!
Is that e30topless'?
Way overpriced too.
bmw-mad
Post Thu Feb 03, 2011 8:59 pm
Pete you have pm :wink:
Im in the market for a e36 myself
mabz
Post Thu Feb 03, 2011 10:11 pm
Royalratch wrote:Dude it's YELLOW!
Way overpriced too.
i love dakar yellow i cant be the only one :o: had a dakar yellow compact,loved it then got bored.im constantly looking so ill keep an eye out whats your price range,preffered colour mileage etc.
Andyboy
Alpina Colada
Post Thu Feb 03, 2011 10:30 pm
Don't diss the Kahns Bruv!
With some suspension and 16 inch double spokes it'd look okay. I'm not adversse to Dakar.
Post Thu Feb 03, 2011 11:29 pm
I love daker as well!
An unmolested dakar E36 M3 or Z3M coupe please!
The finance director for Chandlers BMW has an individual dakar E92 M3!
