E36 Compact Compact 328i ti M sport
- E30 Zone Meets/Events Team
Got it in yet then Lee??
leeparkes
No
ive been getting little bits together ready for the swap.
The plan is for this weekend
Might pop down then on the weekend, got to get the startermotor in tomorrow.
leeparkes
Its alive
(again
Went fairly straight forward apart from me forgetting i had to swap the lives over from one side of the loom to the other where the battery's located
Worked flat out all day Saturday and the new lump was in by the time id finished, just had to sort the loom out
which i did today along with sorting the coolant pipes out, EWS swapping and other general bits to sort out.
Then turned the key, it roared into life after a few cranks, let it tick over for about 5 seconds then gave it a blip then switched it off, back up in the air and put the exhaust on
Dropped it to the floor, double checked everything then went out for a 'test drive' everything's fine and it runs so smooth with no funny noises apart from the alternator sounds a bit iffy but apart from that everything is good. Put your foot on the loud pedal and this thing turns into a lunatic after 5K, im very pleased
Quick question though, whats this for?
The plug to it is on the same line as the maf plug, ive pulled it off and blanked the pipe for now but what is it for?
Cant wait for the blast to work tomorrow
Good to hear
That is the fuel tank vent valve, just vents the fuel vapour from the carbon canister to the throttle body if you have it plumbed in still.
(Should be in the bin)
leeparkes
Arrh,i see, ill leave it blocked off then
Started pulling the old lump apart tonight to see whats what with the head gasket issue.
once ive pulled the head off im pulling the crank out of it but will i need to undo that super tight 22mm bolt from the front of the crank to get it out?
Dezzy
- CR24v it's a lifestyle
Yeh. It's fooking tight too!
I snapped a breaker bar on it! I used big stillys in the end with a scaffy bar on the end.
Well done Lee
leeparkes
Dezzy wrote:Yeh. It's fooking tight too!
I suppose i should of undone this whilst it was still in the car
Is it a reverse thread?
Dezzy
No normal thread mate.
leeparkes
Its only scrap alloy i might break the coont out
town325i
if you do break it out a 3/4 inch gun and a vice will be enough to get it out and maybe a little heatleeparkes wrote:Its only scrap alloy i might break the coont out
leeparkes
/\/\/\ This is the plantown325i wrote:if you do break it out a 3/4 inch gun and a vice will be enough to get it out and maybe a little heatleeparkes wrote:Its only scrap alloy i might break the coont out
Bit of an update, i set about the old engine to see why i was getting pressure in the system, removed the head and took some pics,
Cylinders 1 & 2
Cylinders 3 & 4
Cylinders 5 & 6, Check the iffy white fluffy bits in cylinder 6
Still not sure whats gone wrong though although i did notice a couple of the head bolts near the back of the head came undone a bit too easy whereas the rest cracked undone.
No noticeable cracks anywhere in the block or the head
Any idea's?
Is that carbon staining around No2 combustion chamber or just oil? Check around the valve seats for cracks, the colour of the valves on 5 and 6 doesnt look too good, if the bolts felt loose the threads have probably pulled
leeparkes
No its just oil, im getting the head pressure tested next week to see if that throws up anything.
leeparkes
Havent got the head tested yet as i have more pressing matters to get on with, ie sorting the back box out
The one thats on is a custom back box but its for a 1.9 so im guessing its a bit restrictive with the b28 blasting through it, the plan was to use the 328i back box off the donor car but its a bit too long and hits the diff so i decided to chop some off and weld it back up, perfect fit, twin pipes and OEM
I sized it up and started cutting (through 3 skins
Here's a pic of where its cut
I was under the impression they were a conventional exhaust with two pipes in and two pipes out packed with wool, how wrong i was, check this out.
WTF
Fail
WTF
Fail
Can't see the pics Lee
town325i
The standad compact 318ti exhaust is about 2 to 3 inches from the cat back surley thats enough for it to flow well its only the tail pipe that can restrict it
harry_p
ooh, that's pretty mad
i guess my e36 m3 back box is similar? might explain why it's so quiet, and why theyre known for being heavy!
i'd be tempted to keep the silencer casing but make it a more normal exhaust through the middle of it. standard looks, good fit, better noise
cheers,
harry
harry
penton08
looking at those pics a 318ti exhaust might be less restrictive!! intresting pics tho
Thats why they are so heavy mate
You could do with something like this if you are going to build it yourself -
http://cgi.ebay.co.uk/Custom-Straight-t ... _768wt_913
Dezzy
If i were you i would look for some perferated baffle tube. Join the to main pipes front to rear and pack with wool. It will sound a bit fruitier too
If you get stuck give me the size you need and i will get on to bozal once i am back of my holiday
leeparkes
After seeing all those bends etc the the standard box i think your right Mark it could be more restrictive than what ive got on now, from what i can gather all those pipes inside are to do with the 'flap' in one of the tail pipes so when the flap is shut its not suffocating the engine on the one pipe. the 328i box has twin 46mm OD pipes and the 318ti is 52mm single with none of the curly nonsense inside
Dezzy thanks for the offer but the 328i back box will go to my scrap pile but not after ive opened it up a bit more, im curious to how it works, im not sure if there's wool in the other half as its blanked off ( you can just see the plate on the last pic) Ill update when the autopsy is done
Im not sure what to do now, Dan, i think that will be a bit on the loud side
although yesterday i was at Himley hall classic car show and on one of the stalls a guy was selling Cherry bombs
i was trying to imagine what an M52 would sound like with a pair of them on, bet its mental
Ive even been considering E30 boxes as they are twin pipes and 46mm
Re-think time
Re-think time
ti box is no good, I bodged Kos's with the ti box to get it home and it was obvious there was a big power restriction, even though there are a load of bends and open pipes that 2.8 box will still have enough gas flow, its purely for noise reduction, with one smaller pipe ala ti box its restricted before it gets to the back box
Area of 52mm pipe section is 2122mm2
Total area of twin 46mm pipes section is 3322mm2
Thats more than a 50% increase
A single 3 inch pipe is 4298mm2
Dezzy
Fooking hell Dan is there anything you dont know?DanThe wrote:ti box is no good, I bodged Kos's with the ti box to get it home and it was obvious there was a big power restriction, even though there are a load of bends and open pipes that 2.8 box will still have enough gas flow, its purely for noise reduction, with one smaller pipe ala ti box its restricted before it gets to the back box
Thats more than a 50% increase![]()
nickso
- Location: Go do that voodoo that you do so welllllllll!!
interesting.
does anyone know what the flap on the tail piece is actually for? further noise reduction? seems a bit odd.
i'm considering going single 3" pipe from the manifolds back on mine to keep the weight down.
i would advise against a cherrybomb BTW. if my m52 is anything to go by serious hearing loss will result......though you have an interior in yours which may help.
'88 e30 328i M52 track bint.
Its to keep the noise as low as possible at idle/cruising engine speeds, the only bad thing about 3 inch pipe is ground clearance by the RHD footwell and rear beam
nickso
it's pretty low already dan so i would have to do some measuring. its not as not as low as the sump or the PS cooler though. if i did the manifolds again (can't wait
) i could get them closer to the footwell.
off topic does anyone know why a pipe swager is so fecking expensive? £500 for a manual one, i looked for the diamond encrusted handle but came to the conclusion they are just robbing bastards.
leeparkes
Cheers Dan for the figures
ill mull over them later.
Autopsy is done
Have a look
What you think of that lot
Autopsy is done
Have a look
leeparkes
Nickso, i had this Powerfail system on one of my E30's, 46mm twin pipes up to the centre box with single 70mm out, then 70mm pipe up to the back box
It used to catch where it went under the rear beam.
nickso
hmm, might bin that plan then.leeparkes wrote:Nickso, i had this Powerfail system on one of my E30's, 46mm twin pipes up to the centre box with single 70mm out, then 70mm pipe up to the back box
i'll probably try to find an M3 exhaust and bodge it onto the downpipes.
leeparkes
If you did go single pipe you could 'flatten' the pipe where it goes under the beam.
nickso
yeh but i would always consider it a restriction and never be happy with it.
Dezzy
If it were me i would go straight through 2 single pipes. Forget the rest and re cover with shortened box. Just make it fit and fill it with wool. job doneleeparkes wrote:Cheers Dan for the figuresill mull over them later.
Autopsy is done![]()
Have a look![]()
ANIMAL!!Dezzy wrote:Just make it fit and fill it with wool. job done
