is this a good engine for a conversion?
eko
Old timer
Sat Aug 19, 2006 3:08 pm
I know nothing, any ideas? good or bad? if good what would be needed?
http://atsearch.autotrader.co.uk/WWW/CA ... 2101382164
320Touring
Sat Aug 19, 2006 3:10 pm
words like "high miles and oil leak" set the alarm bells ringing 8O
i'd have been in there before you (saw it at 6am on fri morning) otherwise, make a proper kouncil king khariot
eko
Old timer
Sat Aug 19, 2006 3:16 pm
Long way from you though Neil,only up the road for me winkeye
Are these not strong engines?
Oil leak common problem/easy fix?
I assume it is a V8?
Which manual box would be used?
320Touring
Sat Aug 19, 2006 3:18 pm
dude, to me, Kiev is a long way, london is a daytrip!
yeah its v8-4valves per cyl and this is an early one-4.0 instead of the 4.4 one
nikasil issues abound
as for the gearbox, pass :D
Dan318-is
Sat Aug 19, 2006 4:08 pm
im 99% sure that will be an auto tony. m60 lumps had nikassil issues didnt they? an everett article once informed me that you must NEVER stop adn start them for short journeys; once they are turned on they must be left to warm up completely then switched off, this is what iv read. your on the rite track i think.
re you going to swap running gear too?
eko
Old timer
Sat Aug 19, 2006 4:23 pm
^Dan just spotted it last night,started thinking all sorts of E30porn about sticking it in this -
http://www.e30zone.co.uk/modules.php?na ... 275#432275
but ive just been reading about nikasil and dont fancy all that crap,might just stick to a 2.5!
Dan318-is
Sat Aug 19, 2006 4:25 pm
pussy! none of that m20 wrongness. its less advanced that your current lump. get an e34 525 with the m50 lump and do it, and use the five stud running gear, beast!
eko
Old timer
Sat Aug 19, 2006 4:27 pm
318-is wrote:pussy! none of that m20 wrongness. its less advanced that your current lump. get an e34 525 with the m50 lump and do it, and use the five stud running gear, beast!
This is still an option winkeye
320Touring
Mon Aug 21, 2006 8:57 am
only problem with your plan 318-is is that e34 suspension wont fit on the e30
needs to be a mix of e36/compact stuff or e30m3 gear.
eko-just fit an m30!
mikey-t
Mon Aug 21, 2006 8:59 am
man invented the hacksaw for such reasons! anything is possible just dependant on the limit of your skill and money
bazman
Mon Aug 21, 2006 12:53 pm
Tony - PM me if you are interested in the E34.
Baz
"Build a man a fire, and he'll be warm for a day. Set a man on fire, and he'll be warm for the rest of his life." - Terry Pratchett.
