Blasting my wheels...what media?
E30WES
Post Mon Nov 12, 2007 2:04 pm
I have done a bit of blasting in the past and am gonna refurbish my wheels over the next couple of weeks?
Got a single bag glemco pot and lines...just need an opinion on what media would be best suited to alloys, considering how soft they can be. Everything I have used in the past would be much to harsh.
Post Tue Nov 13, 2007 9:51 pm
I think you mean 'medium'
Glass bead is the proper way to do it but I have used kiln dried sand from the builders merchants before with no problems
billgatese30
Post Wed Nov 14, 2007 12:03 am
i would use something very fine, glass is probably a good bet as you can get it very fine, but it tends to have softer edges than sand too, which should make it a lot less harsh on the softer alloy
if you can't get anything other than really harsh/sharp stuff, use a low pressure to start with and keep on going over and over so as to not eat into the alloy too much
E30WES
Post Thu Nov 15, 2007 5:13 pm
me·di·a 1
n. A plural of medium. (medium? media????)
Thanks for the advice though. Gonna try kiln sand at low pressure to start with as you suggested.
Regards
