best thing for removing glue from paintwork
oakey
I have a wing with the glue from some Ducktape left on it. Any advice as to what products are good for removing it?
StuBeeDoo
HartgeH27
hairdryer - heat - rub
oakey
Rub with what matey?HartgeH27 wrote:hairdryer - heat - rub
Turbo-Brown
- Boost Junkie
WD40 and a bit of soft cloth should do the trick
aceraf
Get some panel wipe, also known as panel degreasant. It's used by bodyshops and it removes most stuff from paint without removing the paint. Any good paint supplier should stock it.
Breaking 325i Touring
d6dph
Autoglym intensive tar remover, put some on a tissue, leave on glue to soak for 5-10 mins. wipe clean
oakey
Thanks for all the ideas lads!
I used Mykal sticky stuff remover- worked a treat. 5minute job and there was glue all the way along the wing
Apparently citric acid is what all these tar/glue removal products contain, so in theory some lemon juice would probably do the trick also
pretty good wing now for a tenner eh
oakey
Fekkin HELL yes!Simon13 wrote:pretty good wing now for a tenner eh
Nice one Simon
fuzzy
thinners and some 80 grit sandpaper should remove it i think.oakey wrote:I have a wing with the glue from some Ducktape left on it. Any advice as to what products are good for removing it?
or perhaps maybe some autoglym intensive tar remover.
maxfield
80 grit and thinners! Bye bye paint
Dave's idea sounds good, he knows his shit when it comes to paint work.
fuzzy
no one mentioned saving the paint just something thats good for removing glue.maxfield wrote:80 grit and thinners! Bye bye paint![]()
