Key Scratches! HELP!
AllieE3o
Need help! im' wanting to sort out my Boyfriends body work"! some Nasty person has keyed his car down the drivers side! What do i need to do? sounds silly that i have no idea! But i love These cars and i know how much he loves them and thought be a good idea to get it sorted as a surprise, so if some one could help i would be grateful !
pukar
lowey
If you could post some pics up would help - it will depend how deep the scratches are as to whether you can polish them out yourself or whether the bodyshop is the only way.
1989 325i SPORT Brilliantrot
mabz
i had good results using cocktail sticks to finely apply primer/paint/lacquer then using 3000 grit to wet sand it and then some farecla g3 compound,and then polish.
this cost me around £15 but its obviously not perfect as the colours are hard to match due to original paint has oxidised over the years.hope you get it sorted mate
polsta
buy a small tn of touch up paint from paints4u , around £10, and some g3 compound from halfords and an applicator waffle pad
1st try the g3
deep scratches, i once removed a biggun in rear quater, as above filled it with a line of touch paint, left for a week to dry/settle in, then g3 to smooth/blend the touch paint, good clean,polish,wax after, and it was 99.9% dissapeared and looked magic, very impressed for a 1st time go at something like that
1st try the g3
twoscoops
pop some close up photos help and then we can beter advise you
