If you don't know what I mean, there's a hammered style black paint (which is rubbery) on the bottom half of my rear bumper.
I want to colour code it silver, seen it done before and looks 100x more tidy. What paint is suitable? How do I go about respraying it? Or is it just a case of sanding it all off and starting from scratch?
Ruberised paint on bottom of bumpers
cee
1990 Sterlingsilber 318iS - 146 bhp / 192 Nm
m8782538
you can over paint, its Gravi-gaurd or something similar. I was asking about this earlier in the week as i need to replace both sills and sort out the rear valance and want to colour code is as OE spec.
You can either get it in a bottle and use a Shultz gun (gives the effect) or in a aerosol version which apparently works too much the effect is not quite the same. Bodyship will probably to it pretty cheap.
Mask off, key and spray. take them no time at all.
cee
So just lightly sand the black paint and spray silver over? No need for primer etc? Sounds brilliant
m8782538
thats what i was told, however, personally i would give it a key with a scotch pad, a light coat of primer and then go over in bodycolour. Luckily my car is black so a bit easier. Not too sure if OE was body colour fr and rr and black on sideskirts as i have seen white e30's with black sills.
cee
I was planning to keep the sides black as I think it looks better
My front is already silver, so just need to do the rear.
m8782538
key, prime and spray then, good luck with it.
cee
Thanks, you too.
