Anyone know who/where stock it??
Windscreen Trim??
crazybitchfttf
The plastic trim that sits in the rubber???
smithy318i
You can buy it from the dealer.
Or you can buy it off a zoner who is breaking an E30... (ME)
You have PM.
You have PM.
HartgeH27
I got mine done when the windsrcreen was replaced ..........no extra charge !! They stock it at most windscreen places, ask nicely !!!!
scottybeemer
imposible to fit without the correct tool,you can buy one ,but i just made one,only took ten mins to make,and it worked great
"you aint gonna take me alive, copper"
smithy318i
what does the tool look like, as i just used a screwdriver when i did mine.imposible to fit without the correct tool
Steve318i
I fitted a new rear one on my car, didn't have a fitting tool and just about managed it with a blunt screwdriver some lube and an old filler spreader. I did my one on a cold day and cracked the chrome inside a bit on the corners. I guess you need to put the trim in a bucket of hot water or do it on a hot day to stop this happening.
scottybeemer
it's a small diamond shaped piece ov wire with a handle,i just used a welding rod bent to shape and a old file handle and some washing up liquid ,there's to much risk ov a screwdriver sliping and scraching the paint work(and it only took about 20 mins to do)
