Shot blasting/powder coating engine?
urfy
Post Tue May 18, 2010 7:52 pm
My engine is out and before putting it back in i want to make it look clean.
is shot blasting or powder coating an option?
or what else can i use to clean & paint the engine?
stup86
Post Tue May 18, 2010 7:59 pm
Before doing anything, you should ask yourself this:
"What will I see of the engine when it's in the bay?"
Then if you can be bothered, clean those bits.
But to answer the question I don't think the whole engine can be shot blasted unless its taken to pieces. I may be wrong, I'm sure someone will come along and correct me.
Parts needed:
M40/M20 ignition coil with high voltage lead
grantfk10
Post Tue May 18, 2010 8:32 pm
A good going over with Gunk, or some other degreaser should do the job.
bobbin1982
Post Tue May 18, 2010 8:39 pm
As above i would go with degreaser and then a tin of black hammerite and a paintbrush... and maybe some hammerite spray laquer to finish?
Andy
Driving my digger!!!!
urfy
Post Wed May 19, 2010 12:45 am
thanks .... will the hammerite be heat resistance? and I guess its the normal hammerite paint you get in the local DIY shop.
bimanut
Post Wed May 19, 2010 11:08 am
Halfords do engine paint
snakebrain
Post Tue Jun 22, 2010 7:53 pm
But do you really need it? I'm sure I've seen people on here saying they did theirs in regular Hammerite and it was fine.
I only mention it because I've been painting my rocker cover all afternoon with the high temp enamel stuff and it's a proper bugger to get a good finish. Streaky city. I'd use hammerite next time if I was sure it would take the temp ok..
