Wheel refurb
SamiS
Formerly illmonkey
Post Tue May 05, 2009 1:17 pm
My 14" BBS' are covered in tiny black specks and some other marks. I have gone over them with wonder wheels, clay bar etc and nothings shifting them. Is it possible for me to do a sand/respray on them, or too much effort?
Any tips to remove the tar/stubborn brake dust?
maf260
Post Tue May 05, 2009 1:31 pm
Autoglym intensive tar remover has always worked well for me. Takes quite a bit of elbow grease as well, but you get results.
Available from Halfords and all other good automotive stores.
The_Diddler
Love it up the more door !
Post Tue May 05, 2009 1:49 pm
maf260 wrote:Autoglym intensive tar remover has always worked well for me. Takes quite a bit of elbow grease as well, but you get results.
+1, will probably be little tar spots, the autoglym stuff should deal with thatas stated above :D
BespokeAlloys
Post Tue May 05, 2009 1:50 pm
You can sand them down and respray, use 600 grit wet and dry. clean the surface and spray. its very easy, if you want a 100% job get the tyres bead pushed down, if you have any curb damage simply use a sander (180 grit) and sand until the alloy is smooth make sure you dont create any dips or lines, apply primer, paint and finally clear coat laquor. I have been refurbing alloys for the last 3 years now its very easy if you follow the simple steps.
Alternately:
There is an acid you can get for alloy wheels its very strong, its available from autosmart.
feel free to email me any further questions you may have (buzzbnow@hotmail.com).
B
