MTech2 Front Spoiler Without Foglights???
StuBeeDoo
OK. I'm getting an MTech2 front spoiler for the Touring and I don't have foglights.
Fitting foglights is not an option, so which of the following do you think is preferable, bearing in mind that the spoiler needs work anyway.
1) Mesh the foglight, oil cooler and air-con holes?
2) Mesh just the foglight holes?
3) Smooth-over the foglight holes and slightly re-shape/enlarge the brake ducts?
Personally, I prefer the third option although it's going to be more work. What do you lot think?
aceraf
Hate mesh on e30's. Do a photoshop to show what you mean about opion 3. easiest thing would be just to fit fogs, and not wire them in. problem solved.
Breaking 325i Touring
StuBeeDoo
I don't have photoshop and if I did probably wouldn't be capable of using it.
What I'm thinking is something similar to these, only maybe not quite so big.
(My apologies to Spadge for nicking his photo')
I don't particularly want to go the mesh route as I think it's "council". Am I right??
Chris-W
George_Of_The_Jungle
gimp is a free version of photoshop, available on the internet
http://www.gimp.org/
StuBeeDoo
StuBeeDoo
toby
Yes option 3 sounds good and more cooling air to the brakes potentially. I don't imagine you'd have to do much. I'm sure I've seen examples of this option somewhere.
leedg
leave them empty....
toby
The scoop bit that normally goes in next to the fog light shown here,
can you not use those instead of fog lights?
Turn them around and use nearside one for offside and vice versa, adapt to fit.
Alyman
Get your hands on a cheap set of fogs then build up a few decent layers of of primer on the lenses. Sand them flat, then spray them body colour and install.
Ain't nothin fills a foglight gap like a foglight
320Touring
lol! Aly to the rescue yet again!Alyman wrote:Get your hands on a cheap set of fogs then build up a few decent layers of of primer on the lenses. Sand them flat, then spray them body colour and install.
Stuart- I'd fit fogs mate, even if not wired.
your car is too nice for any "schlaaag look" tactics...
Ziggy
If they don't fit as standard, I'd still expect some foglight blanks (from a standard facelift valence) could be made to work?
suzie650
Meshing is council, but not that council...
Imagine this extended to the fogs, and a nice custom air duct behind it to at least use the drag created by the big hole
Not too bad, is it?
Not too bad, is it?
StuBeeDoo
That's pretty much what I was thinking.toby wrote:The scoop bit that normally goes in next to the fog light can you not use those instead of fog lights?
I used to have a photo' somewhere of a German E30 Touring with the foglight holes meshed - that was what made me think of it. I'll have to see if I can find it.
Neil, when I had foglights, I got through 2 and a half pairs in 18 months. I may have been unlucky, but I've been put off by that experience.
suzie650
If you're looking for photos, e30.de, under "fotostories"... Only good stuff in there. And hardly any m20b20/25. it's at least 2.7, or s50/s38. Great suff!
As for your problem, you could also try to make covers out of fibreglass yourself? That is if you don't want to mesh them.
StuBeeDoo
That's another thing I've been thinking. Fibreglass + modded standard scoops = bigger scoops and no foglight holes.suzie650 wrote:As for your problem, you could also try to make covers out of fibreglass yourself? That is if you don't want to mesh them.
I think the photo' I'm thinking of did come from e30.de.
euan
i think the idea of just painting over fog lights is genious !!!!!!!!!!
