can any one talk me through wiring a push button start switch to a 1986 e30 please. thanks.
does anyone know what colour wires i need to take from the ignition block to the new switch ect.[/code]
wiring a push button start to an 86 model
zaust
- Zone day release
- Location: Somewhere in Hertfordshire , or press Ctrl + W
HairyScreech
Thews
hi, yeah want to keep the key for electric and steering lock.zaust wrote:black yellow to the push start as this is the starter. You want to leave the key for the rest of the electric and steering lock. ???
zaust
- Zone day release
Thews
thanks very much, so the 2 terminals on the back of the new switch, the one marked "to source" goes to the black and yellow, the other marked 12v+ goes to any live is that right?zaust wrote:Just the black/yellow then. Cut it. extend it to the button. And then when your key is in the on position, Press the button for the starter the wiz over..
zaust
- Zone day release
Thews
Great, thanks for your help mate.zaust wrote:Make sure it is a good 12v thickish wire. I would take it from the constant when cranking one on the ignition myself and use the same gauge.
