are those aftermarket angels eyes or did you build them youself? Seems like the light bulb isn't positioned properly to shine through the ring completely. See if the bulb is crooked or something.
there are 4 peanut sized bulbs that make these work, same happened to mine a little while back, take the unit apart and change the bulbs, will brighten it up loads...
