Help - Replacing bonnet badge
nailsgrant
Post Mon Apr 02, 2007 12:13 pm
Just bought a new BMW badge for the bonnet of my 320.
Does anyone know if the just pop off or what the best way to do this is.
Just don't want to go hacking around and damage the paint work or anything.
Thanks in Advance.
Chris-W
Post Mon Apr 02, 2007 12:22 pm
Pop the bonnet open and you will be able to get to the two lugs from underneath the bonnet to push the badge out.
cougar
Post Mon Apr 02, 2007 12:30 pm
open the bonnet and you will see the under side of the badge it will be 2 prongs sticking out just push them evenly with a small screwdriver
current cars, 4 e30 tourings, 2 e30 cabs, 1 e36 328i sport, 1 e36 328i cab
mrLEE30
Post Mon Apr 02, 2007 2:12 pm
fishing wire every time, two pieces under the badge and pull up, the underneath with a screwdriver can scratch the paint underneath and lead to rust.... this technique also works for the rear bagde and removing the 320 badge
Chris-W
Post Mon Apr 02, 2007 2:17 pm
Eh? How can you damage the paint with a screwdriver if you don't even touch it with it?? The holes in the bonnet are lined with little plastic spigots, no risk of damage unless you use a pry bar to do it!
choppa7
Post Mon Apr 02, 2007 2:33 pm
ha ha ha when I replaced mine I did it the good old way of using a scrwedriver and duster to avoid damaging the paint, although I did hack the shit out of a bonnet at a scrappy trying to get a new badge so knew I had to be careful and where the lugs were.
Didnt know you could just push them out :o:
1990 318i Lux
nailsgrant
Post Tue Apr 03, 2007 8:44 am
Cheers lads.
I'll let you know how I get on.
The fish wire and screwdriver combo sounds like you man. :x
mrLEE30
Post Tue Apr 03, 2007 6:07 pm
by missing and scratching the paint obviously :roll: this cannot happen with fishing wire
Chris-W
Post Tue Apr 03, 2007 6:12 pm
Should be ok as long as you get an adult to help when using metal tools....
mrLEE30
Post Tue Apr 03, 2007 6:32 pm
i normally get my mum to do this as i am only qualified on 12,13 and 15mm spanners, not got my screwdriver badge yet :wink:
Chris-W
Post Tue Apr 03, 2007 6:36 pm
Ah, you're in the spanner-scouts, lesser known and oft maligned off-shoot of the sea-scouts. :D
mrLEE30
Post Tue Apr 03, 2007 6:52 pm
dad told me when i am bigger i can play with the 17 and possibly the 19 spanner :eek: big toys
