constant live fo sterio
Ravi
Post Mon Mar 21, 2005 1:08 pm
my memory keeps going when the car is turned off, does any 1 know if there is a constant power source to the car sterio? i have got a sony head unit, i have been told i could use the power from the ciggy lighter but im not too keen in this. Im hopless at diy
Guest
Post Mon Mar 21, 2005 3:13 pm
you could take the feed from the clock, there should already be a bmw loom for the radio anyway - its a green/red wire,
the bmw loom goes into behind the glovebox
(heh ive learnt a lot about bmw looms today....)
placey
Post Mon Mar 21, 2005 8:42 pm
ravi
the car permanent live should be grey/red - this is supplied in the loom for just the stereo and hence won't have to supply anything else. check this with a multi-meter or a bulb. if you can't find this then i'd recommend feeding a wire from the battery positive terminal via a fuse rather than branching from something else.
paul
i saw a doctor and she gave me some pills....
Dom
Post Mon Mar 21, 2005 8:56 pm
markwd wrote:you could take the feed from the clock, there should already be a bmw loom for the radio anyway - its a green/red wire,
do you work at sextons??
mrLEE30
Post Tue Mar 22, 2005 6:08 am
check the tech article it is all explained.
mr lee :hammer:
jog5000
Post Thu Mar 31, 2005 10:18 pm
I used the wire from my glove box/torch charger. Works a charm.
