Components in front
jessieparsons1
Post Wed Dec 14, 2011 5:50 pm
after considering audio options, i think im going to fit component speakers to the door kicks and get the tweeters mounted up on the wing mirror pannel. has any body done this before? need some info on how to vut upen the existing kicks for the larger speakers i intend to fit. the compnents i have are focal 6.5" had them fitted in a previous car but all working a sounda puka.
other ideas i need is any good hiding places to put a small mono amp for my comp's, with out running shit loads of cable!
if any one has done a similar ice upgrade please could you get in contact! CHEERS THEN
Happy X-Mas
beemerbird
Post Wed Dec 14, 2011 8:07 pm
BMW produced tweeters for the triangular panel you're talking about. Put a 'wanted' ad up - someone may have some for sale. Many cars were wired for them (even if they weren't fitted) so it literally takes a minute to fit them.
If you're not keen on the OEM tweeter audio response, the fitment is perfect and quick, so you could pull out the old drivers and install ones of your choice.
Just make sure you get tweeters with all the fitting clips.
harry_p
Post Wed Dec 14, 2011 10:16 pm
i don't think it's possible to open up the lower pannels, it's quite a structural area and i wouldnt want to be chopping it about.
i know people have built pods outwards to fit 6.5s in the footwells, but you'll have to do something about the bonnet release handle which will get in the way.
cheers,
harry
makman
Post Wed Dec 14, 2011 10:22 pm
im doing this soon mate, fitting 17 comps in the front, i think its possible to fit shallow ones in and cut out a ring of metal to open the whole up. If you take the kick plate pannels off and look where the speakers mount, the metal is very flimsy so it cant be structural there, although all the metal behind is.
Canny Beat a chromie!'
Jozi
Post Sat Dec 17, 2011 1:40 pm
Think you need to get tin snips at the kickpanels to open them up a bit. As Beemerbird says bmw have tweeter pods, wiring should be behind the door card as well, seem to go for under 50.
I'll have a digg around for the thread, someone on here fitted larger speakers and ended up using a audi tt bonnet release lever.
---edit---
Found it here: http://www.e30zone.net/modules.php?name ... ic&t=30618
jessieparsons1
Post Thu Jan 05, 2012 12:53 am
Hey guys just thought I would give this an update currently building my Own door pods! Not sure what they will turn out like but been following some guides and having a bash! Got loads of pics il put a thread up!
funge
Post Fri Jan 06, 2012 8:56 am
Might want to check these out, i have them and they are great!
http://www.audiosport.co.uk/bmw.htm
hongkongfuey
Mad-tango-geezer
Post Fri Jan 06, 2012 9:10 am
Ive put mine in the front doors too, ive got 6.5" shallow fit ones with a spaced ring. Also have put the tweeters on the mirror backplate, why spend £50 on tweeter pods, make your own
with cars like mine,
jessieparsons1
Post Sun Jan 15, 2012 10:41 am
They look so similar to what I have built! Does anyone know how I can put pictures up?
BenHar
Post Mon Jan 16, 2012 12:31 am
jessieparsons1
Post Mon Jan 16, 2012 5:05 pm
