I was thinking where the ashtray is infront of the gear stick, any other suggestions?
Something like this is what i mean...
Nah that's too out there.Stoney_god wrote:I like the jap style ones on the windscreen pillar...
Yea the carbon fibre is a bit of a concern with that as im not sure if carbon will look.."chav", i just want bits that are one off if you get me.E30BeemerLad wrote:Needs to look original though otherwise it can look a bit lax power IMO
any ideas or templates to go off would be greatOLD AND USED oil psi + sender+ tee and twin holder, vdo volts, vdo kp/cm 0-5 , vdo temp 40-120,
