Taking out parcel shelf?
golf_killa
Post Thu Feb 03, 2005 10:16 am
I need help on taking out the parcel shelf as i want to fit speakers, but i cant find any way of getting it out, anyone got any ideas? :?
Simon
Post Thu Feb 03, 2005 1:04 pm
Remove the rear seat bench and backrest, ( bench lifts out, seat back needs 2 small bolts undoing in the lower corners then that will lift and pull out too) undo the seat belts at their lower mounting points, then you should be able to grip on the parcel shelf and lift it (it will be secured by 1 small plastic clip) then it shoud pull free feeding the seat belts through the holes in the parcel shelf.
golf_killa
Post Fri Feb 04, 2005 7:04 pm
:D Cheers mate, it was the backrest that i got stuck on, sorted now.
