Thanx
Does anyone have a step by step on how to fit an amp/sub E30
Cypriotgeeza
As the title says please peeps..would save me alot of time/hassle if i had something to go on
Thanx
Thanx
Check my M30 build threads:
Cypriotgeeza
i take it no1 has fitted an amp to their bmw? lol
- E30 Zone Meets/Events Team
I have, but mine took me a good day, as I took out all the seats trims etc....
Sub and amp are both in the boot.
Do you have a battery in the boot??
Cypriotgeeza
No my battery is in the engine bay...as i said i was jus wondering if anyone whos done it before could lead me in the right place so i dont take out un-necessary stuff and take twice as long to do it
Is your sub in a box??
What you need to do is place the amp and sub roughly where you want to put them.
Then work backwards from there to the front of the car.
That's how I do it.
That's how I do it.
hazd31
youll have to drill a hold in the bulkhead! run it through interior into boot
i cheated with mine by running it through the wing but it is a lillte messy! would never do this on a car i was being payed to fit it,
Cypriotgeeza
lol yea i had it all set up in my corsa...but that was a simple small car! i had a look at the E30 and thought "hmm this is going to take a while" lol i guess theres no 'quick fix' lol
No, no quick fixes.
Cypriotgeeza
It's not an all day job IMO.
Need to remove the door kick-panels (run the amp wire here), remove rear seat to thread wires through.
You need to drill a hole in the bulkhead, i have a pic somewhere.
Couple of hours
Couple of hours
Cypriotgeeza
couple of hours i can handle...all day and ill rip more than just the seat out hahaha
To make life easier, remove the drivers seat for a bit more room
Only 4 bolts.
Main thing is getting the wiring right, all hidden so you can't tell
eko
- Old timer
Under the brake servo in the engine bay you have a large rubber grommet,I would run your main + lead through that rather than drill the bulkhead!
Run your RCA leads along the centre of the car under the centre console/rear carpet/rear seat base.
Cypriotgeeza
Imys E30-- you shouldve seen my corsa mate you never wouldve known! i HATTTEE seeing wiring all other the place..looks so tacky!
Eko--thanx alot for the info
:thumb:
mk2escort
easy mate, i ran the amps battery cable through an existing gromet, right next to the battery, so no need to drill the bulkhead, then i simply unclipped the sill protector on the drivers side (or whatever they are
) then lifted the edge of the carpet, hid the cables, then when it came to getting the wires into the boot, i lifted the boot carpet out and theres a gap in the bottom corner of the boot behind the seat on the drivers side, and you can get the wires into the boot through there. as for the rda leads n the remote wire from the head unit, i ran them straight out the back of the unit, then across the top of the peadals and ran them into boot with the battery cable, that make sense???
Cook318IS
running battery cables with rca cables can cause interferance on the stereo btw
you would have plenty of time in 2 hoursIt's not an all day job IMO.
as said above run RCA and power cables down different different sides of the car or you have rally car noises on the radio
ive got mine positive going through the bulkhead next to the battery tray under carpet and since it was done with carpet out across the floor and through the rear firewall on the passangers side, then the rca and remote come from back of radio down the passanger side and into the firewall with the power cables
then you need a suitable earth, some speaker wire and a few tie wras, tape, screws etc to hold it all in place.
Personally i would do away with the Sub unless you want to shake the cars in the hood, or at least amp and upgrade the speakers first,
ive got comps in the front and some nakamichi 6.5s in there rear and they produce quite puncy bass thats enough for me, now ive got the Naks in the rear i can run plenty of bass through them and at volume too, ive got an amp that produces 4x 50w RMS which sounds no more than alot of headunits, but when headunits say 50w its usually the max power and are probably only producing 28w rms
Cypriotgeeza
Thanx for everyones input!
Alex- i did the exact same thing in my old corsa..i upgraded the speakers and amped my 6x9's so make it a bit more bassy and i was happy with that untill i seeked a bit more bass and got my sub..what a difference that made!
and since then i really miss the kick a sub gives so im prob going to fit the sub at some stage..def have to improve the speakers first
i had a sub, looked ugly, didnt need that much bass, kepy falling over so i binned it
Cypriotgeeza
as i said i was happy with my 6x9's untill i hooked up the sub then there was no turning back lol
It's all about the bass, i've got a 1000WRMS sub
Cypriotgeeza
You should hear it kick, its foooking awesome
Need a more powerful amp now
Cypriotgeeza
what sub and amp are you running?
DB Audio 3000w (1000W RMS) sub and a Vibe Slick A3 monoblock amp
Looking for a more powerful amp as the Vibe is only 750W RMS
