would like to know what the above spoilers are and if they are worth anything
You know what I mean, I heard there were different kits for cabs and incidently assumed that there were different...mrLEE30 wrote:cabby tech 2 spoiler????first time i have ever heard such a thing.... thought (to the point of being quite sure) there was only 1 type of mtech 2 spoiler.
this appears to be a mtech 2 copy, the lower part of the spoiler should curve upwards to match the lines of the upper part, your appears to be the standard plastic/rubber boot spoiler with a second tech 2 copy added on top. The join where they meet at each edge of the upper and lower spoiler also do not appear standard
the orginials normally had M Technic stuck in a small recess just above the ''5'' of your 325 badge.
you can see a picture below.
as for its value somewhere around 10-20quid if copy or 30-50 quid if original.
good luck!!
I agree!!hoikey wrote:think its a copy then
Plus sill covers differ between 2 and 4 door as 2 door have slots for the rear quarter pods to hook into.mrLEE30 wrote:I agree!!hoikey wrote:think its a copy then
C2 for info the all tech 2 parts are same for tin top and cab except the lower sill covers, they are slightly different on a cab to cater for the wider sills required to make up for the lack of roof. then of course the 4 door/touring have different door pods to allow for rear door, but front/rear bumper and spoiler are identical accross the board.
mrlee
