Standard speaker sizes
Dezzy
CR24v it's a lifestyle
Post Wed Dec 10, 2008 9:34 pm
Whats the biggest size speaker you can fit in the stander places front and rear on the e30. I dont want to start cutting things and having tacky speakers on show. I just want to inprove the sound quality as much as possible. Thanks
Post Wed Dec 10, 2008 9:44 pm
rear you can fit 6.5" with some help from a stanley knife but if you dont want to cut then 5.25 and fronts are 5.25
Dezzy
Post Wed Dec 10, 2008 10:13 pm
Thanks mate. What sort of job is it to open the backs out, Dont want it to look bodgy.
Post Wed Dec 10, 2008 10:21 pm
well my e30 has allready been done for 6" speakers but i think a stanley knife will do the job of making the hole a bit bigger, prehaps someone can confirm ???
sati
Post Wed Dec 10, 2008 11:06 pm
yep , its easy to do just use the speaker grill and take teh grill off and draw around the hole in the middel as this will give you the prefect size hole . cut it out with a sharp knife.
heres my back shelf which i cut out for 6x9 a lot more work but well worth it.
Dezzy
Post Thu Dec 11, 2008 8:49 am
Thanks alot for your help. Spot on friendly site
A18RPF
Post Tue Dec 16, 2008 2:11 pm
This is a daft question i know but how do you go about gettin the front speaker grilles off? I had a go but heard some loud creaks so stopped. Do other panels around them need to come off?
stu_316i
Post Tue Dec 16, 2008 2:23 pm
There is a screw in both of the kick panels which needs to be undone, and then on the passenger side you will need to unscrew the bonnet release aswell. It might be easier for you to drop the glove box to get access (open the glove box and push out the 2 plastic pins holding the straps on)
When this is done it should be easy to get the kick panels off.
I think thats everything? 8)
A18RPF
Post Wed Dec 17, 2008 1:52 pm
cheers => i'll try it in daylight this time
