Rear Headrests Query
frogman
Does anyone know if front and rear headrests are identical, the same size and interchangable?
The reason I ask is that I want to retrofit rears to my 318is but cannot seem to find any (with matching pattern), however, I could easily pick up a couple of front ones...
frogman
Excellent, this should be ab easy job.
Cheers.
Cheers.
frogman
Does anyone know if the guides for the headrests are in the coupe seats already?
I think the touring has them not sure about the coupe.
Chris-W
I have done this job on my car. The brackets cost me about £15 inc postage bought from a zoner, I had replaced the seats in my car already but kept the originals which were the same trim pattern so just re used the front headrests in the rear. Takes roughly an hour to do including removing and refitting the seat back.
The only nerve racking bit is cutting the holes in the top of the seat back but if you fit the brackets first and then poke a pen or something through them to mark where to cut the cloth you won't go far wrong.
I was well pleased when I did mine - looks factory :
blyoss
I attempted to remove my rear seats. i got the bottom bench out fine, and the arm rest was no problem. can you tell me how you got the backs of the seats off please? may have been obvious i only did it as a test run.
Also how easy was it to fit the brackets.
At the very bottom of the seat back there is a metal strip at each side which is bolted to the side panel of the car. You can only see the head of the bolt with the rear bench out. Unscrew these, pull the backrest upwards and outwards and there you go.
The brackets on my car for some reason didnt fit straight on and were a bit fiddly, however with a bit of patience its not difficult.
tomson
They only difference is the rear convertible ones are different, the rest are the same.frogman wrote:Does anyone know if front and rear headrests are identical, the same size and interchangable?
frogman
Nice job Rob hopefully mine will lokk that good when I manage to track down a set...
helga
can you fit rear headrests to a convertable??
[URL=http://imageshack.us]
NatDJ
- Dyson deviant
Yes I have them fitted on mine.
cliffybabe
- Powered by Nelly
as Daryll said it aint a problem to fit them in a cabby
NatDJ
- Dyson deviant
OTT Neil but I spoke to Martin at Mirage last night. He said to tell you to pull your finger out and send the partcliffybabe wrote:as Daryll said it aint a problem to fit them in a cabby
cliffybabe
- Powered by Nelly
Alpina99
What's the difference with convertible rear headrests & are the fitting brackets the same ??
Gone, but not forgotten !!
tomson
brackets are the same but the headrest is slightly smaller to allow the roof to fold down without catching them......Alpina99 wrote:What's the difference with convertible rear headrests & are the fitting brackets the same ??
Alpina99
Thanks, now all I need to do is get a pair,
adit
i have headrests and fitting kits available. adi 07901 888019
Alpina99
Thanks,
I'll bare that in mind but they'll be at the end of the project,
cliffybabe
- Powered by Nelly
tomson wrote:the headrest is slightly smaller to allow the roof to fold down without catching them......
