Post
Thu Jun 26, 2008 10:37 pm
I think it's made out of ABS plastic. ABS can be reconstituted and as strong as original by simply welding more ABS to it.
To make an ABS "glue", cut up pieces of ABS and mix that in with acetone or the chemical MEK. The pieces will melt and turn into a sludge. That sludge can be applied to the crack and will weld the pieces together. You can get cans of the sludge as well as it's sold to weld ABS plastic plumbing pipes together too.
