I currently have FLI 5.25" components in the front, FLI 6.5" spekers in the rear shelf (someone has butchered the card part of the shelf and enlarged the hole in the metal shelf, Twat!) Both are running off of a Pioneer DEH-65BT head unit.
I'm planning on using some Infinity reference 5.25" components in the front and ditch the rear speakers replacing the shelf with an unmolested item.
Sub wise I'm going with a Infinity perfect 12 sub powered by one of their mono amps, I have had this set up with the previous generation of amps and was chuffed with it.
What I was planning was to make a baffle that runs the width of the boot and have all the audio hidden behind that, So I need to find a sub box that mounts the sub on the angled face. Any suggestions?
And I also need some carpet that matches the original boot carpet?
