Citroen suspension on e30?
E30Mark
Have you ever driven a Citroen
Go sit in the corner!
PM for details
PM for details
have you been on the crackpipe?!
hey I thought the ride on the XMTurbo I had was cool
That's nearly as bad as putting a ford engine in a BMW.
On a serious note, guessing you want a cheap way of slamming it with adjustable ride height. Slam it with the angle grinder. Or pay the price for air bags/hydraulics.
320Touring
ease up lads!
Its not too far off the principal behind air susp on showcars in terms of dropping/raising etc.
depends what you want the car for.
Ziggy
Exactly what I was thinking. Yeah it's French scrap & I'd never do it myself, but it would look damn cool...320Touring wrote:ease up lads!
320Touring
its not a silly question. we have members with ford engines, jap v8s etc fitted. so why cant someone suggest fitting another manufacturers suspension system?Jon_Bmw wrote:Neil imagine Brianmoores response for 1 second. It would be something along the lines of:
Do not taint bmw's brilliance with french leaky scrap.
Ask a stupid question, get a silly answer?
as for Brian, he'd proabably be interested in the mechanics of making it all work
What shitreon with hydralics suspension is A) Reliable B) Better than stock bmw stuff in terms of handling?
The only reason I can think why people would want hydralic suspension is to get over speed bumps if there car is phat and low innit. And other companies cater for this market.
I still think its a dumb question
Ziggy
Citroen BX = 50p & a pack of space raiders. Airbag suspension = rather more £Â£Ã‚£Ã‚£. You wouldn't fit airbag suspension for the handling gains either...
i'd suggest that a citroen hydraulic suspension system would handle considerably better than an aftermarket airbag or hydraulic setup.
i stumbled accross a vid on youtube a few weeks ago of an old topgear handling test which had a lotus elan, ford granada and a citroen xm doing a slalom. the citroen looked impressively composed, almost matching the lotus.
cheers,
harry
harry
I think its a funky idea for a show car not somthing i'd do, i dont remember snoops asking how well it would handle or how reliable it would be, i dont think this is no worse than fitting a ford engine in a bmw
snoops
- Major Helmet
you got itJon_Bmw wrote:What shitreon with hydralics suspension is A) Reliable B) Better than stock bmw stuff in terms of handling?
I still think its a dumb question![]()
'IF' it did happen its not like I would be driving like im on the track all the time is it? especially with citroen suspension, I was thinking of the aesthetic side of things
calm down lads it was only a question
whats that supposed to mean? I don't see the problem with some on here, i'm from birmingham so whats wrong with that? I asked a serious question, I can seehow it can be seen as stupid but I thought this was a forum about e30's not a kids playgroundDan318-is wrote:Location location location..... AGAIN!
if you can, you should install the citroen suspension, just check every review on the net and you will only get 5/5 stars. Don't listen to these chavs, they have oem sicknes
Axel
BMW 320i Touring (M20B25 RD Headers)
tylerma
- Contact:
bit of an oxymoron theremaxel wrote:Don't listen to these chavs, they have oem sicknes
guy's if you cant give the man a answer to his question simply dont post
allow me to demonstrate
dont know if it will fitsnoops wrote:can a hydraulic suspension from the Citroens be made to fit the e30?
has anyone ever tried this?
and I've not heard of anyone thats tried it
that was easy wasnt it
HairyScreech
it wont be a direct fit and im not sure if the citroen uses mcpherson strut fronts or not but its worth a shot, anything can be made to fit.
(on the bmw being better than other makes in the sus department the mcpherson strut came from ford origionaly)
no reason to get personal here, u didn't even answer the question, i wasn't trying to answer the question, just everyone were saying it was stupidtylerma wrote:bit of an oxymoron theremaxel wrote:Don't listen to these chavs, they have oem sicknes
Axel
munky30
- 100% Pure Council
A lot of cars on hydraulics use modified citroen 'spheres' to make the ride more easy to live with.
They'll have a switched system that can either use the spheres or not, one for go, one for show.
Rayvern have now developed a system that uses a shock and spring placed inside the car linked to the hydraulic system to the same effect.
Both of the above will run into big money, 1500+
If you want a fast lift but no tricks like three wheels etc, a 'fast-air' system of proper airbags will run you in at approx 2k. That will lift and drop in a second or so, allow for front to back, side to side etc.
If you're just after the ability to deck it and get over speedbumps a cheap basic air-ride setup will more than suffice. These are pretty slow to lift and drop though and still set you back 1k+
You could achieve a similar effect by mounting citroen suspension in an e30. In theory all you would need is to fabricate top mounts and attach the struts to the hubs then mount the pumps etc. As has been said, handling wouldnt be all that for racing etc, but for pure comfort citroens are damn good so you would get that benefit too.
- Kos
- Contact:
malcom, why have a dig at maxel ??maxel wrote:no reason to get personal here, u didn't even answer the question, i wasn't trying to answer the question, just everyone were saying it was stupidtylerma wrote:bit of an oxymoron theremaxel wrote:Don't listen to these chavs, they have oem sicknes
i think the ten comments before his were harsher and direct at snops, maxels got a point about 90% of this forum not liking anything away from OE or OEM +
320touring made it simple and clear not to lay into snoops for a simple question, maybe you should follow his lead .
www.pukardesigns.com
IG Pukar.Designs
IG Pukar.Designs
- Kos
- Contact:
well maybe he should put the others back line and not single out maxel for an posting innocent comment ??Chris-W wrote:Maxel - Tylerma was just referring to your phrase 'oem sickness' as an oxymoron; it's not a personal insult, just a reference to what he thinks is a mis-matched pair of words.
Kos - it's not a dig at Maxel (see above). In any case, his subsequent comment is in the plural.
Steady.
IG Pukar.Designs
IG Pukar.Designs
Dr Firefly
- E30 Zone Doctor
I quite like the phrase "OEM sickness." Nice original phrase. I think I'll use it sometime - and using oxymoron as a personal insult - classic! Might have to have it on my sig...
tylerma wrote: you oxymoron, you...
Dr Firefly
- E30 Zone Doctor
Anyway, back on-topic Can the citreon suspension take on different driving characteristics as well as just altering ride height? Could you set it stiffer for track racing, and to comfort for ordinary driving? Or is it not that sophisticated?
