HELLO......
essexgirlracer
- Essex meets organiser
I'M IN THE PROCESS OF FITTING AN M50 24VALVE ENGINE/BOX INTO MY E PLATE E30 318, I WOULD LIKE TO KNOW WHAT PROPSHAFT TO USE AS I NEVER GOT ONE WHEN I GOT THE ENGINE AND THE BOX.....
CHEERS MANDI X
CHEERS MANDI X
fowler
- Boost Junkie
there are several ways to do it
Cut and shut props
etc
need to know what gearbox you are gonna be using ???
Cut and shut props
etc
EX A-Tech Workshop bitch !!!
gone but not forgotten
- Homo Hair
turns caps lock off!!
maxfield
You can butcher a prop to fit quite easily and get it balanced cheaply. But depends on the box being used as fowler says.
Welcome, but lose the caps lock
- Homo Hair
if its the e36 box then 328i prop or e30 m3 or chopped
if its the e30 box then the matching prop
fuzzy
a custom prop can be fabricated and balanced for about a ton.
StuBeeDoo
Not exactly, I can think of 4 different M50/M52 box's of the top of my headStuBeeDoo wrote:fowler wrote:need to know what gearbox you are gonna be using ???I think there's a clue there Dude.essesgirlracer wrote:I'M IN THE PROCESS OF FITTING AN M50 24VALVE ENGINE/BOX
StuBeeDoo
fowler
- Boost Junkie
Thanks dan !!!
cliffybabe
- Powered by Nelly
essexgirlracer
Sorry about the caps lock
all I know is it came from a k reg 525IS...... cheers for the help anyway x x
525i sport, that will be a ZF box. You will need either an E30 M3 prop or have one made using any E30 prop and the front half of a prop with the larger size of flange
- Homo Hair
or a 328i prop with an e30 centre bearing the 'wrong' way round
fowler
- Boost Junkie
agreed with dan the 328i prop is the besty way but then you will have to change the final drive ratio
You can use a an 30 325i box yes i know it will a bit pissed by 20 odd degrees but then you can use an e30 prop and diff might be worth tweaking the gear selecta to
before the doubter's begin
The e30 box can be fitted !!! Seen it done
ecah mehtod is ok
oh I have a diff that you require if you use the E36 328I prop you will ideallly need a 3.25:1 i have one if you are interested
Pm for a Price..
ecah mehtod is ok
Pm for a Price..
jmc330i
Its the choice of gearbox that determines what diff is needed, not the prop - I realise what you were saying, but just wanted to clear up any confusionfowler wrote: oh I have a diff that you require if you use the E36 328I prop you will ideallly need a 3.25:1
1992 525i's had a 3.23:1 ratio diff, so the 3.25:1 mentioned above will be fine.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
fowler
- Boost Junkie
cheers dude bit too early not enough caffine in the body yet lol !!
jmc330i
I know that feeling - I dont start work until 3pm and Im still up this early
James
'91 325i Sport
'91 325i Sport
jaistanley
Can the M42 gearbox be used with the standard E30 325i propshaft and not have to fabricate a new gear linkage (or did I just dream that???)?
Whats this about fitting the E30 centre bearing the worng way round Dan? I knew you could use the 328i prop with an E30 centre bearing, just not the specifics..... I thought it'd be easier than finding an E30M3 one and then replacing the centre bearing anyway (so as to 'service' it). I ask because I'll be using the 5 speed E36M3 box and need a bigger flange...
