m20 swedish inlet plenum
midnight
Post Mon Mar 10, 2008 9:33 pm
has any one made up a swedish inlet plenum for and m20 yet? cus i am going to try and fabricate one soon and was just wondeing is anyone had any pics if it has been done before?
chu346
Post Mon Mar 10, 2008 9:55 pm
What is one of those?
Is it like this? http://us.st11.yimg.com/us.st.yimg.com/ ... 1991_72125
appletree
Post Mon Mar 10, 2008 10:30 pm
Sweet!!! :D
Turbo-Brown
Boost Junkie
Post Mon Mar 10, 2008 11:02 pm
I've done something vaguely similar. The hardest part is the cylinder head flange, you really don't need to butcher an M20 inlet and if you start from scratch you get the option of moving the injectors away from the head too (although you could anyway I guess)
chu346
Post Tue Mar 11, 2008 7:55 am
Why would you want to move the injector from the head?
Turbo-Brown
Boost Junkie
Post Tue Mar 11, 2008 8:47 am
Better fuel presentation so more power :D
If you have a look at some of the BTCC engines, they have the injectors (still just one per cylinder) outside of their ITBs. Of course this means the fuel impinges on the butterflies when they're closed but it doesn't seem to cause them any problems running around the paddock.
Like all things it's a balancing act though as too far away will mean lots of fuel drop-out at low engine speeds which might not be so good for economy on a road engine.
Ant
Retired Team Member
Retired Team Member
Post Tue Mar 11, 2008 9:08 pm
^ hence my Q's via Oakey Alex, not second guessing you dude, just one of many reasons I could have "fun" on the B27
midnight
Post Tue Mar 11, 2008 10:12 pm
yeah thats exactly what i wanna build, i was thinking of chopping up and m20 manifold after where the injectors sit in because this will be my first attemp at building on so dont really wanna get to deep into resiting injectors and build whole thing from scratch
Turbo-Brown
Boost Junkie
Post Tue Mar 11, 2008 10:46 pm
Ant wrote:^ hence my Q's via Oakey Alex, not second guessing you dude, just one of many reasons I could have "fun" on the B27
No worries at all dude :D
I honestly don't think you'll have any issues with drop out, I'd recommend connecting up the FPR to the Vac line though just to get the fuel pressure down a bit on light throttle :D
Gunni
Post Wed Mar 12, 2008 12:08 am
The whole reason for inputing fuel sooner is better atomization and when you are running 600hp/liter it becomes a challenge getting fuel working well enough with air.. so more time is needed. we are talking ultimate dragster setups here. 8cyl, 36injectors and so on.
In a production car setup or similar, the only benefit is cooling down the intake charge and getting the fuel better atomized with the air, which is not a concern in a road car to be hones as you could just as well inject even more fuel in.
but it´s for the racing fuel concervative ..
Gunni
@ 2012 VEMS group buy !!
Onz
Post Wed Mar 12, 2008 10:14 pm
will it pass emissions?
Turbo-Brown
Boost Junkie
Post Wed Mar 12, 2008 10:27 pm
Don't see why not.
The slightly wet wall you get with upstream injectors shouldn't be any worse than the wet valve head you get with the injector by the head bearing in mind that the fuel is injected in two halves unless you're running sequential injection, so half goes in when the valve's shut, and the other half when the valve's open.....loosely speaking.
Onz
Post Wed Mar 12, 2008 10:33 pm
i am very interested to see this working now. Was this the car that is going to get ITB's?
midnight
Post Sun Mar 16, 2008 11:25 pm
na im prob gonna make up the plenum and mounting for a single 2wd cosworth throttle body and modify it for use with anti lag, and ad ram pipes into the plemum to create venturies into the cylinders
Turbo-Brown
Boost Junkie
Post Sun Mar 16, 2008 11:34 pm
midnight wrote:na im prob gonna make up the plenum and mounting for a single 2wd cosworth throttle body and modify it for use with anti lag, and ad ram pipes into the plemum to create venturies into the cylinders
Why would you want to create any kind of venturi? You're not needing to lower the pressure at any point in the system so just a plain and simple pipe with a bell-mouth will do :D
Go for a bigger throttle body too, with a nice progressive linkage :D
Onz
Post Sun Mar 16, 2008 11:58 pm
MR Brown, your knowledge astounds me :) What do you do for a living mate?
midnight
Post Mon Mar 17, 2008 6:12 pm
i thought by adding ram pipes it would be decreasing the pressure and speeding up air flow, for when its time for big boost, well ive been looking at burton power stuff and the are selling jenvey single 70mm throttle bodies there, which would be good also
Onz
Post Mon Mar 17, 2008 10:11 pm
Anything from Burton get a thumbs up in my book those guys are awsome!
midnight
Post Thu Mar 20, 2008 4:05 pm
yeah i have had all good dealings from them over my years of owning rs turbos, but the throttle body its self is £274 so kinda pricey
Turbo-Brown
Boost Junkie
Post Thu Mar 20, 2008 10:54 pm
Hooooow much?!
Does that include the linkage etc?
Be interested to see a piccy.
midnight
Post Wed Mar 26, 2008 9:53 pm
Turbo-Brown
Boost Junkie
Post Wed Mar 26, 2008 10:25 pm
Looks like it comes with a cable yolk on it? Guess it'd be easy to swap the throttle cable for one which can wrap around the yolk.
