pin outs for c101 on a 1989 316 please?
corsashmorsa
i asked for help before and gold told to read a post wich wasnt much help as they only had problems with 1 or 2 wires and i need to do the hole lot!
i have the m30 plug wirring i just need the e30 plug now. anyone please?
thankyou
thankyou
johnl320
The photo is from a 1986 316 auto.
pin 1 blue, Alternator
pin 7 green, ignition power feed
pin 13 green/violet, fuel pump feed
pin 18 black/yellow, starter feed
They are what you need to connect to get it running.
hth
john
hth
john
corsashmorsa
thankyou!
any idea were i can get somthing that tells me all of the pins? even if i have to buy it, as my auto data doesnt have bmw wiring
johnl320
No I don't know where you can get them all, there are only a few more pins actually used on this model.
These pins are from a chrome bumpered pre facelift car.
john
john
corsashmorsa
i did have that model but then got another model with the black bumpers, i think its the facelift....its g reg(89)
corsashmorsa
ok, i've got it to turn over.
i've got a spark.
the fuel pump DOESNT prime, but it pumps while turning over.
theres pressure behind the fuel line as i found out when it blinded me when i took it off.
why would the injectors not be firring?
could it be i have no alternator wire?
i've got a spark.
johnl320
If you've got a spark and the fuel pump runs when turning over then I would make sure the fuel pipes are the right way around.
john
john
corsashmorsa
i did make sure they were the right way around, thats how i was temporerily blinded lol
corsashmorsa
ok i've put an led accross the injectors and it flickers.....i think thats what is ment to happen? could it be that i have a hole in my tank and not getting enought fuel pressure? as the tank was nearly completely empty....
any1 selling a fuel tank cheap in reading area? if not i'll weld it and blow myself up lol
I don't think pressurised fuel tanks have been used on cars since about 1905! Whatever is wrong with your car is NOT caused by a hole in the fuel tank!
Which connection on the fuel rail do you have the fuel supply pipe connected to?
corsashmorsa
the supply i have to the connection near the bulk head, sorry if i dont make much sence i'm possibly still drunk. i've tried it on both ends though.
could it be thats it had run out of petrol and from what i was told if a bm runs out of petrol it takes it a while to get going again....and it probably doesnt help the engien has been sat up for nearluy 2 years
johnl320
Is it even trying to fire? Popping back or starter suddenly speeding up?
john
john
Connections sound right - the fuel return pipe is the one that comes from the pressure regulator.
If you have two year old petrol in the tank it's not going to help things - the lighter fractions of the distillate can evaporate over time in a vented tank.
johnl320
Start pilot, get those bores washed
john
john
corsashmorsa
it tried to fire with brake cleaner as fuel......................i gave up on it this weekend. i'll try again soon
corsashmorsa
hoooRAY! rtis running. it sounds great! with only a manifold on. my nieghbours didnt like it much, so i started it up again to piss them off even more as i dont like them. i also set alight to the floor and thier fence from were i spilt petrol. left it running for afew second and then the fence is on fire, was funny though.
good day for me!
good day for me!
