m10
eamo
Post Wed Jan 30, 2008 12:37 pm
anyone bored out the m10 from 1766 to a 2 litre
or just wondering what performance mods can one do with the m10 (dont suggest going m42 or m20 2.5)
I wanna stick with the m10 - thanks!!!
ed325i
Post Wed Jan 30, 2008 12:44 pm
Didnt they make a 2L m10 ?
d6dph
Post Wed Jan 30, 2008 12:56 pm
I think so Ed, It was used in the 2002's iirc?
eamo
Post Wed Jan 30, 2008 12:59 pm
they did
but i think you can get even more perfromance by boring out existing block and using s14 crank?
chips
Was Pzero
Was Pzero
Post Wed Jan 30, 2008 1:19 pm
Interesting thread. I'll be watching this one.
Was there a 16v head ever made that would fit the M10 excluding the S14?
e21Jason
Post Thu Jan 31, 2008 2:01 am
Hi
You can take a m10 to 2.3l I have block bored to 94mm, but a 02 crank is cheaper and forged, and s14 crank works well with m30 pistons and gives about 2.2l.
There are 3 16v heads for the m10 s14 head about £500 used, schntizer 16v + bmw m12 head which are about 5-10k used.
M10 in endurance race trim about 230-40hp full race group 2 e21's were about 260hp.
But if you want m10 power turbo it.
Jason
eamo
Post Thu Jan 31, 2008 10:35 am
e21Jason wrote:Hi
Jason
can you tell me more about this?
drjim
Post Thu Jan 31, 2008 9:51 pm
I'm in the middle of sorting a power upgrade for my e21. As things stand I am going with a 2002 crank and pistons in my existing block. I COULD bore out to 92mm and use some custom pistons (standard M10 block can't go over 92mm without hitting water), but that'd only give me 2.1L for a LOT more money, and probably isn't worth it.
I will be using s14 throttle bodies/injectors (courtesy of e21_jason!) a lightened flywheel (if he ever tells me if it's an M10 or S14 one), a 284 cat cam, maybe some forged/billet rockers, and will have a slightly higher than 6000rpm limit.
So what power to expect - I'd be happy with 150ish, may get more once I get the megasquirt tuned properly, but really have no idea what it'll do until I get it on a dyno though!
Jim
lance1a
South African/Scottish import
Post Thu Jan 31, 2008 10:02 pm
M10B18 with 92mm M30 535i pistons (2.1L) , std rods and crank, 292 D'Bilas cam (clockwise), Racetep 4 into 1 US spec 2.5" equal length header (modify steering column), Mikuni GSX1100 with 190 mains on 290mm x 36mm inlet tract.
It's either this or the motor/box combo from the E34 525i I just PX'd. As I have done most of the work on the M10 already, I am inclined to stick with this.
I saw a Shnitzer head for sale in the states, massive money!
Have a look at Korman Fast BMW and Top End performance sites in the states, but keep in mind the smog laws they have there are very restrictive. :D
BMW E28 528i X2
Merc W126 300E twin turbo
Merc cosworth 190e 2.3-16
BMW E28 525E
BMW E28 M535i
Saab 900 Classic Turbo
BMW E24 Highline Cosmos
BMW E24 Highline silver
BMW E24 Macau Msport
BMW 1972 2002
BMW E36 Alpina B3 3.2 Switchtronic
Renault
drjim
Post Thu Jan 31, 2008 10:11 pm
Hey Lance1a
92mm pistons with 71mm stroke standard crank would give 1888cc, or are you using a 2002 crank??
Your setup sounds a bit like what I am doing, look forward to seeing some dyno figures.
Jim
Post Fri Feb 01, 2008 8:33 am
I'm glad i am normal ! :)
lance1a
Post Fri Feb 01, 2008 8:39 am
drjim wrote:Hey Lance1a
Jim
I started to write a reply but the zone went down last night.
You are quite right, I made the mistake of basing by calculations on a 02 block. So now it's a case of trying to find either an 02 block or an 02 crank. This might swing the swap in favour of the M50B25 though. There was a guy in Essex who had a complete motor for sale, but I have lost his details. The problem is that those with the odd bits and bobs for these cars charge the earth for them.
Oh, well....looks like it might be the 6 pot after all! :(
BMW E28 528i X2
BMW E28 525E
BMW E28 M535i
BMW 1972 2002
Renault
essexboy
Post Fri Feb 01, 2008 8:44 am
i'm also in the progress of building an m10, i'll be using a 2002 block crank and rods, m30 pistons and a 1.8i head, and a holset turbo :evil:
not sure what power it will bring, i'll just wait and see :D
drjim
Post Fri Feb 01, 2008 10:39 am
Fritz's bits have at least one 2L M10 around, E21 engines but same thing.
I scored an o2 crank off ebay for £25, last one I missed went for a fiver!
Andyboy
Alpina Colada
Post Fri Feb 01, 2008 11:13 am
I know of a complete M10 2 litre engine for sale. Worksop area.
eamo
Post Sat Feb 02, 2008 11:19 am
pm details of that 2ltr m10 please boss
