Is this possible?
Rik178m
Post Mon Dec 24, 2007 3:22 pm
I want to do an engine swap but my car has taken a bash before I got it. If I take the engine out will the chassis/mounting points move?
gooner1
Out humping Reindeer
Post Mon Dec 24, 2007 3:25 pm
Would have thought that if they did the car is in a dangerous condition anyway Rik.
Ant
Retired Team Member
Retired Team Member
Post Mon Dec 24, 2007 3:28 pm
if the shell is tweaked then there's a small risk that pulling the Subframe will allow the car to move from its OE setup.
TBH most E30 inner wings are miles out of spec due to stut sag (inwards) so it not the end of the world.
if in doubt, get the welder out and add some Xtra bracing top and bottom with some 40x40 angle to hold it all square(or not :lol) do the deeds you have planned and job-jobbed.
Removal of just the engine and box will not alter the geometry.
Rik178m
Its deff not dangerous its only slight. Ive done over 5000 miles, it drives straight, is solid and has no uneven wear on the tyres. I understand what you mean though mate
Rik178m
Post Mon Dec 24, 2007 3:30 pm
Sweet cheers lads
If the points are going to move, they they already will have, and need pushing/jigging back to where they should be! All the jigging measurements are on the E30 car club, Philippines site : http://bmwe30cc.org
Rik178m
Post Mon Dec 24, 2007 4:45 pm
So the engine won't be holding them?
Yaninnya
Post Wed Dec 26, 2007 1:15 pm
Engine is not holding enything. It is fitted on flexible mounts.
Jan
Gunni
Post Thu Dec 27, 2007 9:10 pm
Also fitting a strutbrace can push the struts back assuming you can first get it on them and the strutbrace is stronger then the struts. I would reccomend strutbraces to all E30´s to maintain stock geometry
Gunni
@ 2012 VEMS group buy !!
