Intercooler Location Q
mattG
Sun Nov 25, 2007 10:26 am
Hi Guys
I need to fit a new Intercooler & wondering if I locate it behind the rad. ie. in between engine & rad (I do have an electric fan.) will it still cool the charged air enough ?
(\__/)
(='.'=)Simon13 wrote:
323's were dangerous this will un drivable in the wet!
MattG - hedgefinding specialist
E21 turbo
Can be your new sig matt!
Ant
Retired Team Member
Retired Team Member
Sun Nov 25, 2007 12:49 pm
no Matt, the heat transfer from the rad will carry that temp increase into the charge
IC up front, rad behind , I can sort you an alloy unit that will fit in the space you have and still allow good rad airflow, viscous can be retained too.
e30_Turbo
Boost Junkie
Sun Nov 25, 2007 1:46 pm
Matt,
Just get a little one like me and slide it in, no one will ever notice :lol:
mattG
Sun Nov 25, 2007 7:32 pm
I was just thinking that on boost you will be traverling quickly and the air coming through the rad might be still be cold enough-since some cars don't even have intercoolers,
I don't want to cut any panels up & ground clearance is a pain at the moment,
But if it would warm the IC up it would be pointless
(\__/)
E21 turbo
Turbo-Brown
Boost Junkie
Sun Nov 25, 2007 8:07 pm
Wouldn't just warm it up, it would get up to around 70 or 80 degrees C, hotter than you should be seeing with a LOT of boost! :(
mattG
Sun Nov 25, 2007 8:55 pm
OK you convinced me, don't put an IC behind a rad.
How about putting theIC where the rad is and the rad right behind or would they be to close together?
(\__/)
E21 turbo
Colonel Sanders
Le Surrender Monkey.
Location: guernsey.... i mean france munching on garlic and drinking wine with my children.
Sun Nov 25, 2007 10:47 pm
pete1979
Boost Junkie
Mon Nov 26, 2007 3:30 am
cutting disc in the grinder remove bumper and cut away then hide it with bumper and mtech2 skirt i did lmao cutting discs and a mig ahhhhh fantastic :mad:
jondrift
Mon Nov 26, 2007 4:23 pm
im just about to mount one behind the front grill. got it off ebay, and its 18 inches by 12, so should fit nicely. Ill take some pics as i go along if you like
Colonel Sanders
Mon Nov 26, 2007 5:14 pm
look at my avatar, 1 hour to fit it properly if you dont mint losing the main beams, it gaves it charicter i think.. :twisted:
mattG
Thu Nov 29, 2007 12:07 am
Cheers guys, but I really don't want to cut any panels so will just fit it like I had it before & proberly fit -35 or -25 springs to raise the car a bit (currently on -60/40).
(\__/)
E21 turbo
