Ok, so the cars wrong but....
Ant
Retired Team Member
Retired Team Member
Post Tue Oct 02, 2007 5:43 pm
Todays toil was excellent, 1961 Covette was 289 now 303 ci was originally carter carbed but today we swopped her to an EFI setup using a TPI kit from a mid 80's Camaro all running from MS
Got some starnge looks driveing the beast around with a laptop connected up, certainly caused a stir with a few visitors to Claremont Corvette, where the car is located.
a few pix, chromius alert !
Next one is a 424 Big Block in an LT3, with manual trans
Hmm, need to find a better home for some lazy SB power, the '61 was spinning the rears on a full throttle kickdown, 3 speed auto :lol:
Forgive the slightly OT nature, but this is one transplant that neds to be done( again , there was a 350 chevy powered e30 that belonged to a zoner waaaay back in the day)
maxfield
Post Tue Oct 02, 2007 5:45 pm
That back end looks stunning!
Pure engine porn!
Ziggy
Post Tue Oct 02, 2007 5:47 pm
:cool: :cool: :cool: :cool: :cool:
d6dph
Post Tue Oct 02, 2007 5:50 pm
Now where did I leave that.....
.... OOh here it is: :drool:
Post Tue Oct 02, 2007 5:53 pm
You can use MS in conjunction with a conventional dizzy?
Way cool ride - pimp!
Ant
Retired Team Member
Retired Team Member
Post Tue Oct 02, 2007 6:04 pm
Maurice, yes dude you can indeed, jumper for opto-in and she'll run from a conventional dizzy, MSD, Mallory HEI, TFI or whatever, this is actually the generic application for the hardware.
This one is running the Mallory HEi type so although its a dizzy in the mechanical sense, its actually controlled via the ECU as were using the optical trigger and 8 rotors as an ECU trigger( as per the 60-2 we use on motronic ) to give engine speed and position to the MS, with the coil discharge timing controlled via the ECU.
Fully 3D mappable fuel and spark, had to be done.
Post Tue Oct 02, 2007 8:53 pm
Too right, thanks for explaining that Ant - I'm even more tempted to have a go at a MS conversion now :thumb:
fowler
Boost Junkie
Post Tue Oct 02, 2007 8:55 pm
320ise do th MS conversion its awesome totally transforms throttle response
car feels allive !!!
EX A-Tech Workshop bitch !!!
gone but not forgotten
Post Tue Oct 02, 2007 8:59 pm
Cheers dude - shall look into it (seems I've gone and knackered my 535i's Moronic anyway...) :o:
tylerma
Post Tue Oct 02, 2007 9:00 pm
top work dude
was this the unit that sat upon your kitchen table a while back
if so damn heavy
bigbhpwannabe
Post Tue Oct 02, 2007 10:32 pm
d6dph wrote:Now where did I leave that.....
pmsl , is dam cool
toby
Post Wed Oct 03, 2007 9:27 am
Great set up mate! The car is a bit wrong but it is beautifully styled and now presumably a lot less thirsty on fuel. Got any pictures of the front of it? So you're in Tom's good books again then?
e30_Turbo
Boost Junkie
Post Wed Oct 03, 2007 10:37 am
Nice ride! I see what you mean now, £75k gone....WOW
I'm sure grandad would appreciate a big block up her!
ste
Post Wed Oct 03, 2007 11:03 am
mattG
Post Wed Oct 03, 2007 8:26 pm
Bit of new skool for the old vett :cool:
(\__/)
(='.'=)Simon13 wrote:
323's were dangerous this will un drivable in the wet!
MattG - hedgefinding specialist
E21 turbo
Can be your new sig matt!
