fitting a 535 engine into e30
austin360
was intrested in the conversion you s make it sound a easy ish job what complications could u hit i know about the engine mount s being different but what prob would the wire n of the engine if u could let me know thanks
gareth
you're best off having a good search and read through the forum firstly.
search for M30 and have a few evenings spare to read through it all!
Rik178m
gareth
...with a few lies.
eg, you can use an auto engine, loom and ecu. just fit a manual box, flywheel, clutch and spigot bearing in the crank.
in the real world, only an electric fan will fit.
in P3, a E34 535i rad will fit.
the standard E30 M3 prop will work without mods in P1, P2 and P3
ther's probably a few others too! good site for a read through
Rik178m
ahhhh that clears some issues I was wondering about aswell then cheers dude
ric325i
dude take a look though my thread *E30,shoehorn,m30* its got most the info you need as i have asked for more info that you could possibly imagine.
lots of pics too
lots of pics too
alan335i
i used the e34 rad in my conversion,and used the standard 325i sport prop with no mods.gareth wrote:...with a few lies.
89 335i sport
ric325i
how did you use the standard prop?alan335i wrote:i used the e34 rad in my conversion,and used the standard 325i sport prop with no mods.gareth wrote:...with a few lies.
mine had to be cut and shut to mix the 535i gearbox and the 3 series dif.
also the lengths are very different
Toby_Unna
- Boost Junkie
how did you use the 325 prop, apart from the length issue the front flange is smaller than that on a 535i gearbox isn't it?alan335i wrote:
gareth
M10 gearbox and flywheel route maybe?
Toby_Unna
- Boost Junkie
guess so!
gareth
yup!
BristolBulldog
My prop's with Charde's still. It had been shortened once before i got it!. Turns out that i couldn't fit anything radiator wise, unless it was in the farthest back postin.
335i.de says you have to modify the bulkhead, i didnt.
Looking for a slim rad e28 is it? failing that i will shoehorn the e30 auto rad i had in there.
What did you guys do with the feed off the oil cooler? I am considering getting pipes made to feed it to the auto oil cooler on the auto rad?
ric325i
i think you will need a 535 rad just because the rad is bigger isnt is?
i beat the bulk head to set the engine further back for better weight balance and to the rad will actually fit in.
so many different ways but they all work
BristolBulldog
maybe the convertible has a different bulkhead (i doubt it). but 335.de's brackets have the engine mounted right back, and it fits (literally just though, just like your pic).
the other rads actually appear to have less heat dissipation. Whilst larger, they are alot thinner.
i can get the 325i auto rad in there, but i may have to stump up for the e28 rad your also looking for. ECP do them right? probably around £140 though?
ric325i
i have no idea? but i got my e34 rad in and so did gall.
my dissy cap has took some abuse so i am getting the engine to sit further back if i can as thats the best place for it
possition 3 if i can. its fun beating the bulk head
charlE30
325 rad if in good nick will work fineBristolBulldog wrote:maybe the convertible has a different bulkhead (i doubt it). but 335.de's brackets have the engine mounted right back, and it fits (literally just though, just like your pic).
On the bulkhead front... it's really strange as everyone says different, I do sometimes wonder what position people actuall have there engines in, not what they think.... God knows what mines in, I had to "adjust" the bulkhead a lot and my M3 prop only just fitted on it's shortest setting and that was using some E30.de copies from karan on here... up front I've got the standard 325 rad and can get a finger between it and the dizzy cap.
Good luck with it all mate
Charlie
BMW E30 344i track car
BMW F31 335d xdrive
BMW F31 335d xdrive
gareth
on mine, i probably have 10 - 15mm of adjustment left on the M3 prop. i have the thinner E28 rad and can't get a finger in there!
i'm using e30.de mounts and i drilled a hole between P2 and P3 (P2.5
) for the mounting.
BristolBulldog
i'm using the furthest back mounting on the 335i.de mounts.
I went for position2, but could fab up to fit my rad infront on the bulkhead.
I put it on the second position (that equates to p3) and can have my original 325i rad at an angle. The dizzy's still a bitch to get around though. The engine had to literally be shoe-horned into place, and i used the weight of the engineresting on the two poly engine mounts, two 17 stone blokes with a rope attached to the output shaft on the back of the gearbox, and a lot of heave-ho to get the thing in there. Seems to have card thickness clearance now, so happy with that.
These mounts.
These mounts.
