what setupn 4 2.7 turbo m20?
hijak001
Post Tue Jul 31, 2007 2:00 pm
hey plp me again
i hav a question...would a 2.5 m20 head
on a 2.7 short block giv a low comp..
low enough 4 a turbo..
ur help wid dis is greatly appreciated
k catch ya's
1an
Post Tue Jul 31, 2007 2:18 pm
there was a guy on here who did a 2.7 turbo, i believe Ant suggested that it was a bad idea doing a 2.7 turbo not to sure your probally best giving Ant a ring and speaking to him about these kind of things.
maxfield
Post Tue Jul 31, 2007 2:20 pm
blingsta had a 2.7 turbo but had problems because he was running pretty hih compression.
With a low compression engine then 2.7 would be a sweet thing to turbo.
Ant
Retired Team Member
Retired Team Member
Post Tue Jul 31, 2007 7:18 pm
I have 3 2.7 turbo projects in the workshop, the CR is the key to this conversion.
only ill advised on ETA cranks due to the weak cast iron nature and long stroke, TD or M52 cranks are stronger than the B25 unit so not an issue, all the converted engines I have built are riunning the TD crank
happy to field a few phone calls on this if you want BTW.
Blingsta was 10.4:1 CR + turbo , hance the Headgasket going into orbit once the boost climed above 8 psi.
blingsta
Boost Junkie
Post Wed Aug 01, 2007 1:24 am
:cry:
turbotel
Post Fri Aug 03, 2007 12:44 am
or a decompression plate /copper gasket a safety valve in other words. this willbe the first item to go should something go wrong depending on what goes wrong. can get you number.
blingsta
Boost Junkie
Post Fri Aug 03, 2007 12:51 am
Ferriday engineering can provide a decomp plate for £300.. 3mm is what i had but bought it too late... :cry:
hijak001
Post Sun Aug 05, 2007 8:51 am
ic so the td crank ...
no da only prob i got is gettin 1 into australia..
:cry:
oh well will a find way..
fanx 4 da help
cplagz
Post Sun Aug 05, 2007 10:49 am
eta block, rods, crank + 325i pistons, head = low comp IIRC ? ~8-8.5 or something
**BANNED**
Post Sun Aug 05, 2007 2:07 pm
Is a 2.8 crank available in upsidedown land?Be stronger than the eta item,would eta pistons/2.8 crank give a useful starting point?
fuzzy
He who sleeps with "Gingers"
Post Sun Aug 05, 2007 2:47 pm
hijak001 wrote:hey plp me again
k catch ya's
how come the text talk filter didnt sort this out?
Colonel Sanders
Le Surrender Monkey.
Location: guernsey.... i mean france munching on garlic and drinking wine with my children.
Post Sun Aug 05, 2007 3:17 pm
maybe hes "special"
hijak001
Post Sun Aug 05, 2007 3:38 pm
hurray i'm special...
lmao..
nah i got no idea y it hasn't
