Anyone got a supra engine in their e30????
oakey
What is involved in fitting it in an e30?
thanks
thanks
dazleeds
- old skool raver
the ausies have deffo done this
may be an idea to check some ausie forums
also lee beemerlad knows a fair bit bout this conversion
afair the engine goes in very easy its just lots of wiring etc
www.oldskoolfantasy.co.uk
oakey
I have the whole car and have no worries with ripping the thing to pieces so transferring the wiring should hopefully not be too much of a problem?
I am POOO at wiring anything complicated
dazleeds
- old skool raver
im pretty sure thats the hardest part fella
i think even the engine mounts line up perfectly
what supra engine have ya got?? what age car
fuzzy
arent you one of the e30 originality bufties
oakey
it will be going in a shitter if it goes in anything.
A fair bit more power than a standard cossie lump aswell. uhum
maxfield
I'd rather have the cossie lump though...
Go ahead with the conversions will make a nice car
oakey
^ would you go for a cossie lump if the supra engine cost £250 with a manual box?
fuzzy
but arent you one of the originality bufties?
fuzzy
maxfield wrote:I'd rather have the cossie lump though...
oakey
whos an originality bufty?
maxfield
The cosworth is a good engine, if tuned properlyfuzzy wrote:maxfield wrote:I'd rather have the cossie lump though...![]()
fuzzy
arent you one of the zoners that believes in keeping things as bmw intended? i might be wrong but i thought you were.oakey wrote:whos an originality bufty?
oakey
I just have a bit of taste matey. (only joking btw) I just like the way (in general) BMW have done things with the e30.
I dont believe in ruining a mint one with mods though. its a bit of a shame
if you don't go ahead with the conversion can you give me first dibs on the supra engine & box?
fuzzy
isnt there a zoner from new zealand or somewhere similar that has done this. cant recall his user name. i looked at using a skyline 2.5TT engine in mine but was advised against using jap due to complicated wiring but other than that itll be the usual sort of fitting problems assossiated with engine transplants.if you can get a good engine and box then go for it .manual boxes are quite rare.good luck.
curryp
- Formerly cuzz1510
this engine will be the 7M-GTE out of a UK MK3 Turbo 3.0L, it's a single turbo, about 230bhp as standard and 260ft/lb of torque.
Power increases are very easily obtained, for about £300 in bits you would have that over 300bhp
blingsta
- Boost Junkie
g57yle (Gary) on the zone has got one in his e30, he was running 500bhp but damaged the chassis thru the power... his currently re-inforcing another e30 shell to transfer all his bits into...
oakey
^ that looks
I'm getting tempted now
jaffro
im starting a lexus v8 conversion soon that should be fun
mrgtsx
someone in sydney australia has done a 1jzgte its the 2.5 litre version of the supra engine he is on here. i am doing a 2jzgte engine in my cab. not overly complicated just have to do wiring. exhaust is on the same side. i would advise not to put a 7mgte they have bad headgasket problems . good luck
they are a problem if not torqued down to the revised setting.mrgtsx wrote: i would advise not to put a 7mgte they have bad headgasket problems . good luck
ric325i
this is exciting talk!
you will learn lots about electrics
but dont let it put you off, think of the power figures and the dents from your fingers in the steering wheel
mrgtsx
electrics are nothing to be scared of! I have sweet fuck al lknowledge but i managed to get 3 cocnversions running. each being a different car. as long as you have both wiring diagrams your set
mrgtsx - have you got the 6 speed manual box with your 2jz lump?
does it drop straight onto the E30 mounts? what about the sump?
mrgtsx
sump clears with no problems. i actualy purchased a 1jzgte 5 speed because i bought the halfcut as an auto from an aristo. im just going to baby it around for a while till i get the $$ them ill fork out for the 6 speed as it is stupidly priced here in australia. engine mounts lined up but needed to be extended. nothin some steel and a welder cant fix. its pretty much a conversion similar to any later model bmw engine. not overly difficult but has its moments
drifty325i
the 5 speed you purchased will be fine, they can handle 500hp easy , been proven time and time again. I presume its a w58 or w57
The V8 in action http://www.youtube.com/watch?v=vp5Eaf8xOgM
if it's a 5sp from a 1JZ it's likely to be a R154 which is a very strong box
Personally I wouldn't pay the premium for the 6sp box, I'd invest the money in trying to get some traction lol
mrgtsx
haha thats my aim at thhe moment focusing on traction. its a fun project i must say and its different.
ric325i
ive always liked the old supra but they weigh stupid amounts!
bring on the supra powered e30!
DRIFTBOY
I thought the problem on these Supras with head gaskets was that leaves and stuff get trapped in front of the radiator causing it to overheat and blow the gasket. Many people had engines repaired only for it to happen again soon after as the blockage wasn't removed.E30BeemerLad wrote:they are a problem if not torqued down to the revised setting.mrgtsx wrote: i would advise not to put a 7mgte they have bad headgasket problems . good luck
Slightly tighter head bolts are often a good idea on tuned turbo engines though.
Interesting project too!
oakey
The engine runs beuatifully. completely silent. A bit dissapointing really- would be nicer if it had bit more 'grunt'
