Will a cam affect
ed325i
Post Fri Jun 22, 2007 1:11 pm
the compression of an engine ?
When I fit a schrick cam will I have to increase the compression ?
Turbo-Brown
Boost Junkie
Post Fri Jun 22, 2007 1:33 pm
Yes, the cam will lower the dynamic compression of your engine. I tapped out a big long post on the subject a while ago, perhaps have a search for that.
Ant
Retired Team Member
Retired Team Member
Post Fri Jun 22, 2007 7:42 pm
100% with Alex, the duration and overlap cost you some cylinder fill ( some is blown out.. ) so long duration requires more static CR, a high lift shorter duration cam will have less of a negative effect on the CR.
ed325i
Post Fri Jun 22, 2007 8:20 pm
So how much should I take off the head to bring the CR back up ?
gcorky
Boost Junkie
Post Fri Jun 22, 2007 10:37 pm
ed325i wrote:So how much should I take off the head to bring the CR back up ?
did you get that cam m8?
525 sport
ed325i
Post Fri Jun 22, 2007 11:29 pm
did you get that cam * I tried to use text speak but the text speak filter stopped me *?
No, I was going to but he wont give me the full part number, I will take your word that its a 304 and not the 284. I was trying to save a bit of money
I will be getting a cat cam.
Post Mon Jun 25, 2007 5:09 pm
i wouldn't skimm the head, i can't see a cam effecting the CR so much that it would be detrimental to the performance. I may be wrong of course
reggid
Post Tue Jun 26, 2007 3:37 am
as turbo brown said a cam will lower the dynamic compression which can be detrimental to a standard compression engines torque curve.
