Turbo-Brown wrote:Oh forking excellent idea!
Don't suppose you've got a part number for those have you?
Do you reckon there's room for two of those on the sump?
Cheers!
Alex,
Ant sourced this for me, so I couldn't even tell you model of landrover it is from mate, he's back 3rd of may.
The actual pipe bit has been cut down quite a bit, I think it was about 6 inchs long before. Only thing I can think of is to send that pic to someone at landrover and ask if they can identify it, but I'll ask Ant when he's back for sure.
And I think there is plenty of room for more, some have fitted the returns to the front of the sump and that has a larger area to tap into. You have fins on the sides that mean you have only a few areas big enough to fit it. But 2 two would fit easy.
HTH,
Mark.
