M52B25 + Supercharger
tubby17s
Post Mon May 21, 2007 1:15 pm
I thought i would introduce myself and tell you about my project instead of just lurking.
My name is Josh and im from sydney Australia
I Bought my car as a stock standard 1990 model 318is, 2 and a bit years ago. after owning 2 previouse E30's
I installed my 2.7ltr alpina spec engine into it with all extras including wheels, suspension, interior.
i then installed a haltech ECU and custome made suspension.
i used re valved commodore (vauxel over there i think) rear shocks... notice the size differance
This is a pic of My old engine.
I then (in the search of some more power decided i needed a better exhaust system and wanted to knwo what would happen if you paid for the best
i was greatly dissapointed as there was not the increased power gain i was looking for.
I decided to add a mtech 2 bodykit and found oen and had it painted quickly.
the engine wasnt feelign the best so i decided to rebuild it and add a supercharger... i purchased an albrex unit that had been on an e30 previously. The kit looked good but i was then looking to update the engine to something newer.
i decided apon a m52b25 with a supercharger.
The engine has ARP bolts Throughout. the rest is fairly standard.
Its running an ASA supercharger with a Delco ECU and Kalmaker software.
This is what we have achieved over the past couple of weeks in between full time work
wiring done, soooo many wires left over :?
I have used a small casing e36 gearbox. thanks to reading on here i have purchased and fitted a mk1 Gti brake booster (have heapppsssss of space now) the problem was that mk1 gti's didnt come to australia and only some were privatly imported which made things hard.
there is a m50 inlet manifold bolted to the head now. i used the 328i exhaust manifold as the group buy on the m3 extractors looked like it was going to take too long (the guys did seem to make a tremendouse effort)
im after a radiator now. my problem is that i need a radiator with the top hose on the exhaust side because the nomal loction runs into the supercharger. if anyone has any ideas it would be great.
i will try and keep you all updated.
Josh
Lennerd320i
Post Mon May 21, 2007 1:29 pm
nice project u're running over there...
ste
Post Mon May 21, 2007 1:54 pm
Very interesting - I'd love to see more pics of the supercharger installation.
I've been giving this more and more thought recently - any more details of the supercharger kit you can give would be really appreciated.
I notice you've got an S50 oil filter housing on there - is that so you can run an oil cooler?
I hadn't even thought that the radiater outlet would be a problem...
maxfield
Post Mon May 21, 2007 2:00 pm
:cool: :cool:
Awesome project!
dom-1984-320i
Post Mon May 21, 2007 2:03 pm
mate that looks like a very nice e30 you are building! keep the pics coming! :cool:
tubby17s
Post Mon May 21, 2007 2:25 pm
Yes it is for an oil cooler.. i just bought an oil cooler and i am going to install it as soon as the clown posts it (stupid ebay)
a top view of the supercharger you cna also see the radiator clearance issue. dont forget the engine will move forward a bit under heavy braking.
belt set up.
im going to be installing the oil cooler behind the kidney grill
Josh
M5pilot
Post Mon May 21, 2007 11:42 pm
Nice work and very intelligent choice of conversion. You should easily see E36 M3 power.
Sorry can't help with your problem but good luck!
ste
Post Tue May 22, 2007 11:39 am
M5pilot wrote:You should easily see E36 M3 power
..and lots more torque. 8)
MR_SAZ
Post Mon May 28, 2007 2:55 am
Josh i`m in homebush way... I have a parts stash now...i`ll look for a radiator for you... i think i might be able to help you...
sash
Ill send you my mobile via PM ok!
oze30
Post Mon May 28, 2007 12:17 pm
you could try for a volvo 240 rad. They are abit narrower across, but they are heaps deeper. If your halfway decent at fabbing things up, it needs a few pieces of bar stock from the bottom of the slam panel to form a rad support.
Plus, you couldl lower it abit more ie, top hose not flush with the top of the slam panel.
That bracket that holds the blower, is it a horshoe shape?
Nice beemer too. I'm in the Chatswood area when I'm in Oz!
tubby17s
Post Tue May 29, 2007 10:50 am
I just purchased a e39 series 1 323i radiator.. that has the top hose on the passenger side. so that shoudl solve my radiator issue.
i am in hornsby
