M50 head / M54 block
alexbaby88
Post Thu May 03, 2007 1:21 pm
Will a M50B25 head fit on a M54B30 block?
dasparkybad
Post Sun May 06, 2007 7:57 pm
sorry dude they are very different
alexbaby88
Post Tue May 08, 2007 5:12 pm
Then will M54B30 crank, rods and pistons fit directly into the M50? This theoretically should give a Bore / stroke of 84mm/89.6mm the same as M54B30. ie iron block 3.0L?
gorgeee
Post Tue Aug 21, 2007 11:56 pm
id like to know the same but if a M54b28 cranks and rods and pistons fit a m50b25
Black Sport
jaistanley
Post Wed Aug 22, 2007 7:32 pm
You could always track down an american M3 3.0 or 3.0 crank rods and pistons and have them shipped over.
I have heard tale that you can use the M54 stuff but have no further details. Try the american forums such as E30Tech, they're always trying to cram more displacement from the M50.
Jai
gorgeee
Post Thu Aug 23, 2007 3:20 am
thanks mate
Black Sport
alexbaby88
Post Fri May 28, 2010 7:26 am
alexbaby88 wrote:Then will M54B30 crank, rods and pistons fit directly into the M50? This theoretically should give a Bore / stroke of 84mm/89.6mm the same as M54B30. ie iron block 3.0L?
The M54 rotating bits are a direct drop in to a M50/M52 block. Easy way to get to 3.0L.
