what ITB setups have people used on an M20?
oakey
Post Thu Mar 15, 2007 6:38 pm
i want to run individual throttle bodies but i cannot find any "kits" and i'm not really sure what exactly to look for or whatever else i need to make it all work?
i know i'll need:
a standalone management system,
intake manifold(where can i get one of these? will it have to be custom?),
injectors
will i need a new fuel rail etc? different fuel pump?
any advice greatly appreciated.
dave
maxfield
Post Thu Mar 15, 2007 9:43 pm
diblas i can't remember how to spell have a look at player6s car.
maxfield
Post Thu Mar 15, 2007 9:50 pm
Dbilas
Turbo-Brown
Boost Junkie
Post Thu Mar 15, 2007 10:07 pm
I'm right in the middle of making a set of custom ITBs for a guy with a great big V8, and the M20 is next on my list if you're interested and can wait a few weeks for me to start on them winkeye
oakey
Post Thu Mar 15, 2007 10:14 pm
Turbo-Brown wrote:I'm right in the middle of making a set of custom ITBs for a guy with a great big V8, and the M20 is next on my list if you're interested and can wait a few weeks for me to start on them winkeye
thats exactly what i wanted to hear! i'm in no rush for them matey.
ive just got a old merc as a runaround for a few months so i do up the e30.
engine and bodywork.
can you run itb's with a turbo set up on an m20 without too much hassle?
i cant yet decide whrther to go forced induced or stay n/a
i will gladly take you up on youre offer Brown.
any idea of price?
:D :D
Turbo-Brown
Boost Junkie
Post Thu Mar 15, 2007 10:27 pm
I'm running a set of ITBs on my current setup and they work absolutely brilliantly :D Throttle response is amasing and the hp/psi is also pretty decent :)
The V8 set I'm doing run to £1300 odd so pro-rata it'd come out at £975, but the linkage is quite complex on the V8 as both banks need syncronising so the price should come down a bit taking that into consideration and also some of the bits I sub out are more numerous on the 6 cyl than an 8 which helps reduce costs :)
stuartgallafant
Post Thu Mar 15, 2007 10:29 pm
alex, i've been told that ITB's on forced induction setup is a bit of a wasted effort. do you really think it makes that much difference then mate?
Turbo-Brown
Boost Junkie
Post Thu Mar 15, 2007 10:34 pm
It seems there are two schools of thought on the matter, one that it's a waste of time, the other that making everything flow as efficiently as possible will lead to more power / psi of boost.
Certainly I subscribe to the latter way of thinking, as did Bugatti (before VW stuck their oar in) on the EB110, Nissan on the Pulsar and Skyline, Peugeot on the 205 T16 rally car and probably a fair few others :)
stuartgallafant
Post Thu Mar 15, 2007 10:36 pm
cool cool, thats a very good point mate. i wasnt snatching, it was just something i got told!
only reason i asked, is because i'll be building my ITB's up soon, and if im ever going to supercharge the engine, i wanted to keep them on there!!
gcorky
Boost Junkie
Post Thu Mar 15, 2007 10:38 pm
stuartgallafant wrote:alex, i've been told that ITB's on forced induction setup is a bit of a wasted effort. do you really think it makes that much difference then mate?
well firstly off boost performance would be greatly improved.
and i believe it does too on boost, but is not as important as it is on na.
more air in=more air out=more power
525 sport
Turbo-Brown
Boost Junkie
Post Thu Mar 15, 2007 10:40 pm
:lol: sorry dude, didn't mean to sound so defensive :)
The only problem you'd have with (a positive displacement) supercharger setup would be venting the boost generated at idle, but it's nothing Lentec hasn't worked around with his down-stream throttle body so I'd say go for it :D
stuartgallafant
Post Thu Mar 15, 2007 10:42 pm
why vent the boost at idle? cant you just run the charger at idle so its right near making boost, without actually boosting?
gcorky
Boost Junkie
Post Thu Mar 15, 2007 10:43 pm
when boosting though with itbs you do then require a more complex intake upto itbs...rather than say a 3 inch pipe upto tb.not a mass problem but something to think about on your initial design.
525 sport
stuartgallafant
Post Thu Mar 15, 2007 10:44 pm
gcorky wrote:when boosting though with itbs you do then require a more complex intake upto itbs...rather than say a 3 inch pipe upto tb.not a mass problem but something to think about on your initial design.
yeah, i had thought about this problem! gonna be a ball ache i reckon!!
oakey
Post Thu Mar 15, 2007 10:45 pm
Turbo-Brown wrote:I'm running a set of ITBs on my current setup and they work absolutely brilliantly :D Throttle response is amasing and the hp/psi is also pretty decent :)
price sounds reasonable dude :D
can you sort out manifold injectors etc? or is that included?
Turbo-Brown
Boost Junkie
Post Thu Mar 15, 2007 10:48 pm
It's only really a problem with positive displacement chargers which are always trying to supply X amount more air than the engine can consume. With the throttles shut, the air's got nowhere to go so the system pumps up and up until something bursts or the drive belt to the charger starts slipping or breaks.
It's no big deal though as you can incorporate a couple of dump valves into your air box which are pulled open by engine vacuum when the throttles are shut in the conventional way :)
Think Len has a magnetic clutch on his charger which disengages drive when the throttle's shut too which helps relieve stress on things too.
Turbo-Brown
Boost Junkie
Post Thu Mar 15, 2007 10:53 pm
That price includes manifolds, throttles, throttle linkage and bracketry to retain the original fuel rail and also the crank case breather pipe.
You'd need to supply your own injectors and, whilst I can supply an air box, people like to be able to play with their tuned lengths so the throttles I make accept standard Weber pattern trumpets.
The design I've come up with allows you to put the air box on top of the engine so that you can keep the runners pretty much the same length as the original plenum intake, or it can be moved closer to the head if your setup dictates :)
stuartgallafant
Post Thu Mar 15, 2007 11:01 pm
alex, did tee/tristan show you the ITB's we have? could you make up a manifold for them to go on my M42? i can send pics
gcorky
Boost Junkie
Post Thu Mar 15, 2007 11:02 pm
Alex,you have it all worked out...lol,how do you find the time?
525 sport
oakey
sounds awesome mate. let me know when youre able to get going on them winkeye
gcorky
Boost Junkie
Post Thu Mar 15, 2007 11:06 pm
525 sport
Turbo-Brown
Boost Junkie
Post Thu Mar 15, 2007 11:09 pm
Can certainly take a look dude, I've gotta give the V8 chap top priority until his project's complete though, will pop some piccies of his setup up when I've got something to show for my efforts :)
It's amasing how much free time being single gives you :lol:
Will do dude :thumb:
oakey
Post Thu Mar 15, 2007 11:11 pm
ive just noticed youre in aldershot turbo brown (squaddy terriory!). not far from me. my g/friend goes uni in farnham
jkarran
Post Thu Mar 15, 2007 11:34 pm
Bike bodies are good value, there's an endless supply of donors! Cheaper than bespoke but nowhere near as cool.
jk
E30 320i Rally Turd - Usually broken
E24 635Csi - Rotting in peace for now
E34 540i - Daily driver
Blown R1 Striker - In progress
Turbo-Brown
Boost Junkie
Post Fri Mar 16, 2007 8:11 am
Small world! :D I'm just down the road in Ash, but people have heard of Aldershot :)
Whereabouts are you Oakey?
stuartgallafant
Post Fri Mar 16, 2007 9:24 am
i know aldershot. down the A3 somewhere if i remember right. is it near new malden?
my dad used to be a driver for Cranleigh Freight Services and i used to go to work with him sometimes, you know, 'when i were a lad' type thing!!
oakey
Post Fri Mar 16, 2007 10:26 am
well i'm not actually that close. i live in chessington/leatherhead but i spend alot of time in farnham so it is sort of close to me. i go to the Burger king in aldershot at least once a week.
stuart- its not really near new malden, NMalden is S.london end of the a3 whereas aldershot is closer to guilford.
95-540iLE
Zone Newbie
Post Tue May 15, 2007 1:20 pm
Any update on this? I am very interested.
Turbo-Brown
Boost Junkie
Post Tue May 15, 2007 1:56 pm
We're working on the specifics for Oakey's setup as his ports are larger than standard.
oakey
Post Tue May 15, 2007 3:20 pm
95-540iLE wrote:Any update on this? I am very interested.
I'll keep updating the thread as and when things happen dude. hopefully it will all be getting started soon. I need to get a standalone management system fitted first. :D
Oh yeah! Turbo-Brown. Would it be ok for you to post me a printed version of the flange? as I'm not sure whether, if you email me the file, the dimensions will be correct
cheers matey :D
If you can get it to me asap that would be awesome as ive got alot of free time this week/weekend
Turbo-Brown
Boost Junkie
Post Tue May 15, 2007 5:08 pm
Coolio Dave, will print one off tonight :D
e21Jason
Post Wed May 16, 2007 12:22 am
