316i tourer engine swap
noddy2004
i have at the moment a 316i tourer auto on a k plate with the m40 engine in it what engine can i drop in with out changing to much if i can have a list of parts needed it will help me out no end thanks
gcorky
- Boost Junkie
m-dtech
- Unapproved Trader caution
big thing there is the word "auto"
your gonna need to change prop, gearbox, diff etc.
1. convert to manual
2. stick in an m50b25
noddy2004
what is the different in the m42,m20 ectgcorky wrote:search m42,m20 swaps
bit more work m30 swap.
noddy2004
what donor car should i look for?
Templ8e30
Doesn't a k plate require a cat come MOT time ?
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
noddy2004
i think it will do does that limit the engines i can use?Templ8e30 wrote:Doesn't a k plate require a cat come MOT time ?
Cheers,
Iain T
Not if the engine is pre August 92 or the engine number is unreadable.Templ8e30 wrote:Doesn't a k plate require a cat come MOT time ?
Cheers,
Iain T
gcorky
- Boost Junkie
im not going through all this again...lolTempl8e30 wrote:Doesn't a k plate require a cat come MOT time ?
Cheers,
Iain T
m42 is the 318is engine 1.8 16v 140 odd bhp
m20 b20 is the 6 cylinder 129 bhp 2 ltr as in 320
m20 b25 is the 6 cylinder 171 bhp 2.5 ltr as in 325
m30 is more ambitious "big six"in 3ltr,3.5 ltr but is more involved than the native e30 engine swaps.
plenty of cheap 325s complete around...best bet,youve got all the bits for couple of hundred
noddy2004
thanks for that time to start looking in the paper for a 325 then
munky30
- 100% Pure Council
316 to 325 swap is 'easy'....
I just did it, had a few hitches along the way but that was my fault.
If I can do it, anyone can.
