yes dude, bought a blolt on kit S/H, bolted it all on, relocated all I could away from the heat of the turbo, sheilded everything else that could not be relocated.
ran it up for an hour to check for leaks and nip everything up @ working temp and ventured out for a drive.... 714 injectors and 4bar fuel pressure, vac off, no exhaust apart from a downpipe and running a puny 5 psi on the 'gate.
hit the bypass for the first boosted run..... wohooooooooooo !
then 3 minutes later engine conked out and refused to restart, opened the bonnet and to my horror I discover the heat from the dwonpipe had melted through a 6mm kevlar/ceramic lined heat sheild and melted the main engine harness where it goes through the bulkhead, Doh !! oh and 3 HT leads looked like molten slugs smeared accross the rocker box
anyways, thats history now, manifold bears no resemblance to the original state I bought it in, its lower and leaner now
It s all taken far too long but it'll be worth it in the end
the MS was a late addition to the plan after I realised a rising rate FPR was a wrong turn for what I wanted to achieve
I set a small budget for this conversion,anything is possible with a blank cheque, I chose the DIY route, under 1.5K fitted and running is the max spend, I'm just under the bar for each setup but get a sneaky feeling I'll soon need more funds for more boost
