Or is it just a case of tying up the loom & slap the carbs on?
Ben
Why not let me quote for a manifold. I can make you one in either stainless or aluminium. I would be happy to re space your TBs or bike carbs as well.stuartgallafant wrote:adam, nicely done for the bogg brothers link!, i think i'll be using them...
forty, 40mm maybe slightly too large for the M42. i've got 38mm TB's, which im told are the perfect size for a 1.8, but you may find that you'll be fine
in regards to the injection/ignition, go MS. thats what i'll be using
and listen closely and carefully to what ant says... he is an uber-guru in his field...
